Parti
Nessuna parte richiesta.
Follow removal of rear housing guide. This should be your starting point.
  • Follow removal of rear housing guide. This should be your starting point.
Aggiungi Commento
Using your fingernail or an opening tool, peel back the first layer of tape, located toward the left side of the phone. The circuit wiring should peel away with the tape. If not, remove the circuit wiring from the terminal.
  • Using your fingernail or an opening tool, peel back the first layer of tape, located toward the left side of the phone. The circuit wiring should peel away with the tape. If not, remove the circuit wiring from the terminal.
Aggiungi Commento
  • Peel away second layer of tape and smaller circuit wiring.
  • Use caution as this wiring is extremely fragile.
Aggiungi Commento
  • Using tweezers, remove wire connecting motherboard to small circuitboard at the bottom right of camera housing. Remove each head of the wire individually.
Aggiungi Commento
  • Pry up motherboard using opening tool to pry circuitboard away from two clasps on the left side of phone.
Aggiungi Commento
  • Pull camera up from rear housing of phone using fingers.
Aggiungi Commento
  • Remove final circuit from terminal on the bottom side of the motherboard using the opening tool.
Aggiungi Commento
  • Completed.
Aggiungi Commento
Conclusione
Ohio State, Team 1-1, Buehl Fall 2012 Membro di Ohio State, Team 1-1, Buehl Fall 2012
OSU-BUEHL-F12S1G1
4 Membri
3 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,228
