Parti
Nessuna parte richiesta.
Objective: remove the rear case from the Motorola Droid X phone.
  • Objective: remove the rear case from the Motorola Droid X phone.
    • This is what the Motorola Droid X looks like before disassembly. In the front, there is a large LCD touch screen.
Aggiungi Commento
INSTRUCTION: Turn the phone over so that the back faces up.
  • INSTRUCTION: Turn the phone over so that the back faces up.
Aggiungi Commento
Objective: remove the battery casing plate.
  • Objective: remove the battery casing plate.
    • The case plate has a push and slide mechanism.
Aggiungi Commento
INSTRUCTION 1: Push on the upper side of the casing located under the camera lens.
  • INSTRUCTION 1: Push on the upper side of the casing located under the camera lens.
  • INSTRUCTION 2: Slide down the battery case plate.
Aggiungi Commento
INSTRUCTION: Insert your finger tips into the edges of the opening and pull the casing off.
  • INSTRUCTION: Insert your finger tips into the edges of the opening and pull the casing off.
Aggiungi Commento
Objective: remove the battery from the battery compartment.
  • Objective: remove the battery from the battery compartment.
Aggiungi Commento
INSTRUCTION: Grab the red tab that says "Battery Release" and slowly lift it up. This will remove the battery.
  • INSTRUCTION: Grab the red tab that says "Battery Release" and slowly lift it up. This will remove the battery.
Aggiungi Commento
Objective:  remove two small black screws from the back of the phone.
  • Objective: remove two small black screws from the back of the phone.
    • These two (2) screws help hold the phone together. They need to be removed by a Phillips Hex 2mm screwdriver,
Aggiungi Commento
INSTRUCTION: Remove two black screws from the back of the phone.
  • INSTRUCTION: Remove two black screws from the back of the phone.
Aggiungi Commento
Objective: remove the two plastic pieces in front of the phone - they cover the remaining screws.
  • Objective: remove the two plastic pieces in front of the phone - they cover the remaining screws.
    • The two plastic pieces are clipped onto the phone as covers. They are located at the top and the bottom of the phone.
Aggiungi Commento
INSTRUCTION: Flip the phone over to the front side.
  • INSTRUCTION: Flip the phone over to the front side.
Aggiungi Commento
INSTRUCTION: Use the iFixit tool as a crowbar to pry the top plastic cover piece off of the phone.  It will pop off.
  • INSTRUCTION: Use the iFixit tool as a crowbar to pry the top plastic cover piece off of the phone. It will pop off.
Aggiungi Commento
INSTRUCTION: Use the iFixit tool as a crowbar to pry the bottom plastic piece off the phone.
  • INSTRUCTION: Use the iFixit tool as a crowbar to pry the bottom plastic piece off the phone.
Aggiungi Commento
Objective: remove four white screws from the corners of the screen.
  • Objective: remove four white screws from the corners of the screen.
    • These four (4) screws help hold the phone together. Use a Phillips Hex 2mm screwdriver
Aggiungi Commento
INSTRUCTION: remove the 2 white screws from the upper corners of the screen.
  • INSTRUCTION: remove the 2 white screws from the upper corners of the screen.
Aggiungi Commento
INSTRUCTION: remove the 2 white screws from the lower corners of the screen.
  • INSTRUCTION: remove the 2 white screws from the lower corners of the screen.
Aggiungi Commento
Objective: remove the rear case from the phone in order to provide access to inside the phone.
  • Objective: remove the rear case from the phone in order to provide access to inside the phone.
    • The phone is now held together by the casing alone. You need to pop the two halves apart.
Aggiungi Commento
INSTRUCTION: Use the iFixit tool like a crowbar to pry apart the front and rear halves of the  casing. They will pop apart.
  • INSTRUCTION: Use the iFixit tool like a crowbar to pry apart the front and rear halves of the casing. They will pop apart.
Aggiungi Commento
Now you are ready to access the internal circuits of the phone.
  • Now you are ready to access the internal circuits of the phone.
Aggiungi Commento
The objective of the guide is to remove the motherboard from the camera. The mother board is an  L-shaped green circuit board.
  • The objective of the guide is to remove the motherboard from the camera.
    • The mother board is an L-shaped green circuit board.
Aggiungi Commento
In order to start, the rear case should have been removed. Follow the rear case removal guide for that procedure.
  • In order to start, the rear case should have been removed. Follow the rear case removal guide for that procedure.
Aggiungi Commento
Let's start. The objective of the following two steps is  to remove the circuit connectors connected to the mother board.
  • Let's start. The objective of the following two steps is to remove the circuit connectors connected to the mother board.
    • They are "clip-on" type connectors which have a black leathery coating. The connectors are located at the lower bottom left part of the "L-Shaped" motherboard.
    • There are two connectors with the larger one overlapping the smaller one. You can disconnect them either by hand or with the iFixit tool.
Aggiungi Commento
INSTRUCTION: Disconnect the larger connector on the top by pulling on the edge of the black coated connector. It will pop off.
  • INSTRUCTION: Disconnect the larger connector on the top by pulling on the edge of the black coated connector. It will pop off.
Aggiungi Commento
INSTRUCTION: The smaller connector will become visible once the larger one is disconnected. Disconnect it also the same way as before. INSTRUCTION: The smaller connector will become visible once the larger one is disconnected. Disconnect it also the same way as before.
  • INSTRUCTION: The smaller connector will become visible once the larger one is disconnected. Disconnect it also the same way as before.
Aggiungi Commento
Objective: disconnect the white wire connected to the motherboard. The wire is visible at the upper left of the "L-shaped" Motherboard. Each end of the white wire is connected by a circular pop-on connector.
  • Objective: disconnect the white wire connected to the motherboard.
    • The wire is visible at the upper left of the "L-shaped" Motherboard. Each end of the white wire is connected by a circular pop-on connector.
Aggiungi Commento
INSTRUCTION: Grab and pull up on the silver connector that is at the end of the white wire connected to the motherboard until it pops off.
  • INSTRUCTION: Grab and pull up on the silver connector that is at the end of the white wire connected to the motherboard until it pops off.
Aggiungi Commento
Objective: separate the motherboard from the rest of the phone.
  • Objective: separate the motherboard from the rest of the phone.
    • The motherboard is held in place by two silver clasps on the left side of the phone.
Aggiungi Commento
INSTRUCTION: Use the iFixit tool to pry the clasps open. This will free the motherboard from the case.
  • INSTRUCTION: Use the iFixit tool to pry the clasps open. This will free the motherboard from the case.
Aggiungi Commento
Objective: detach the camera component from the phone.
  • Objective: detach the camera component from the phone.
    • The camera component is located at the upper left part of the phone, right above the white wire mentioned previously. The camera is square.
Aggiungi Commento
INSTRUCTION: Grab the camera component and pull it  out of its casing. Keep the camera connected to the mother board.
  • INSTRUCTION: Grab the camera component and pull it out of its casing. Keep the camera connected to the mother board.
Aggiungi Commento
Objective:  disconnect a circuit connector from underneath the motherboard to finish the process.
  • Objective: disconnect a circuit connector from underneath the motherboard to finish the process.
    • The circuit connector is a gold and black colored "clip-on" type connector located in the middle left side of the phone. It is connected to the underside of the motherboard.
Aggiungi Commento
INSTRUCTION: Slowly lift up the motherboard as you would turn a page.
  • INSTRUCTION: Slowly lift up the motherboard as you would turn a page.
    • The motherboard is still connected to the phone.'''
Aggiungi Commento
INSTRUCTION: Use your fingertips to grab  a edge of the connector and pop it off.
  • INSTRUCTION: Use your fingertips to grab a edge of the connector and pop it off.
Aggiungi Commento
Conclusion: Now, you have successfully removed the motherboard.
  • Conclusion: Now, you have successfully removed the motherboard.
  • At this point, you will be left with the following: 2 black screws, 4 silver screws, 1 motherboard, 1 camera, 1 rear case, 1 battery, 2 plastic pieces from the front case, and the rest of the phone.
Aggiungi Commento
The objective of the guide is to replace the camera component on the motherboard.
  • The objective of the guide is to replace the camera component on the motherboard.
Aggiungi Commento
In order to start, the motherboard should have been separated from the rest of the phone.
  • In order to start, the motherboard should have been separated from the rest of the phone.
    • Follow the motherboard removal guide for that procedure.
Aggiungi Commento
Objective: separate the existing camera component from the motherboard.
  • Objective: separate the existing camera component from the motherboard.
    • The camera component is connected to the rear side of the top left of the motherboard. The connector is a black colored tab which is a pop on type mechanism.
Aggiungi Commento
    • It is up side up is when it looks like the capital letter L.
Aggiungi Commento
INSTRUCTION: Have the motherboard upside down.
  • INSTRUCTION: Have the motherboard upside down.
Aggiungi Commento
INSTRUCTION: Flip over the golden circuit   tab .
  • INSTRUCTION: Flip over the golden circuit tab .
Aggiungi Commento
INSTRUCTION: Pull on the edges of the black connector tab and pop it off.
  • INSTRUCTION: Pull on the edges of the black connector tab and pop it off.
Aggiungi Commento
OBJECTIVE: Attach the replacement camera component to the motherboard.
  • OBJECTIVE: Attach the replacement camera component to the motherboard.
Aggiungi Commento
INSTRUCTION: Pop on black connector tab of the new component at the same place where the existing one was removed.
  • INSTRUCTION: Pop on black connector tab of the new component at the same place where the existing one was removed.
Aggiungi Commento
Conclusion: You have finished replacing the camera component of your phone.
  • Conclusion: You have finished replacing the camera component of your phone.
Aggiungi Commento
Conclusione
Gage
Membro da: 27/09/2012
1 Reputazione
1 Guida realizzata
Ohio State, Team 1-1, Buehl Fall 2012 Membro di Ohio State, Team 1-1, Buehl Fall 2012
OSU-BUEHL-F12S1G1
4 Membri
3 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 634
