Salta al contenuto principale
Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement
Cosa ti serve
  1. Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement, Antenna/Headphone Jack: passo 1, immagine 1 di 2 Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement, Antenna/Headphone Jack: passo 1, immagine 2 di 2
    • Remove the SIM card.
    • Remove the microSD card.
    • Insert the plastic opening tool between the back cover and the front piece of the case, freeing the plastic clips between the phone.
    • Do this along the back right side of the phone cover until you reach the top.
  2. Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: passo 2, immagine 1 di 2 Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: passo 2, immagine 2 di 2
    • Use the plastic opening tool to carefully work your way around the top of the phone, freeing the plastic clips.
    • Be cautious when using the tool around the top of the device because the plastic case is very thin and could easily be cracked or snapped.
    • After this continue using the tool and pry down the remaining side and the bottom of the phone.
  3. Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: passo 3, immagine 1 di 3 Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: passo 3, immagine 2 di 3 Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: passo 3, immagine 3 di 3
    • With all the plastic clips released, pull away the back cover from the phone to remove it.
    • The back cover is attached to the battery with a large amount of adhesive. Some force may be required to pull the back cover from the phone.
    • The back cover is very durable and will not break from some bending or pulling.
  4. Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: passo 4, immagine 1 di 1
    • Looking at the top rectangular hump where the camera is located, you will now use the plastic opening tool to remove the camera cover.
    • With the plastic opening tool, apply pressure into any surrounding crease of the camera cover to remove it.
  5. Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: passo 5, immagine 1 di 3 Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: passo 5, immagine 2 di 3 Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: passo 5, immagine 3 di 3
    • Using the T5 and T4 bit pieces, remove the silver screws located around the rear case of the phone.
    • Remove the three 6.7 mm silver T4 screws that are located at the top of the phone.
    • Remove the five 4.0 mm silver T5 screws that are located near the middle of the phone.
  6. Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: passo 6, immagine 1 di 1
    • Using the T4 bit piece remove the three black 4.5 mm screws that are located at the bottom of the phone.
  7. Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: passo 7, immagine 1 di 3 Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: passo 7, immagine 2 di 3 Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: passo 7, immagine 3 di 3
    • Insert the plastic opening tool between the rear case and motherboard assembly.
    • Using the plastic opening tool, carefully work your way around the phone, freeing the plastic clips.
    • Carefully pull the rear case off the motherboard assembly.
  8. Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: passo 8, immagine 1 di 2 Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: passo 8, immagine 2 di 2
    • Use the tip of the spudger, lift the red silicone cover off the battery terminal screws.
    • Remove the two 3.3mm T5 Torx battery terminal screws.
    • Grab the red battery removal tab and pull the battery out.
    • There might be some adhesive between the battery and motherboard assembly.
  9. Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: passo 9, immagine 1 di 2 Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: passo 9, immagine 2 di 2
    • Using the T5 bit pieces, remove the silver screws located around the metal chassis.
    • Remove the three 3.5 mm silver T5 screws that are located near the middle of the phone.
  10. Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: passo 10, immagine 1 di 3 Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: passo 10, immagine 2 di 3 Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: passo 10, immagine 3 di 3
    • Using the plastic opening tool gently lift the microphone out of its resting place.
    • Using the plastic opening tool gently lift the front-facing camera out of its resting place.
    • Be careful not to pull and disconnect these devices.
  11. Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: passo 11, immagine 1 di 3 Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: passo 11, immagine 2 di 3 Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: passo 11, immagine 3 di 3
    • There are four clips that must be released at the top and sides of the phone before the Antenna/Headphone Jack can come completely off.
    • Using the plastic opening tool, carefully pry the Antenna/Headphone Jack piece off the motherboard assembly.
Conclusione
Altre 2 persone hanno completato questa guida.
Nick Kraese
Membro da: 10/08/14
657 Reputazione
2 Guide realizzate
USF Tampa, Team 14-6, Leahy Fall 2014 Membro di USF Tampa, Team 14-6, Leahy Fall 2014
USFT-LEAHY-F14S14G6
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,551
