Salta al contenuto principale
Motorola Droid RAZR M Front Assembly Replacement
Cosa ti serve
  1. Motorola Droid RAZR M Front Assembly Replacement, Front Assembly: passo 1, immagine 1 di 3 Motorola Droid RAZR M Front Assembly Replacement, Front Assembly: passo 1, immagine 2 di 3 Motorola Droid RAZR M Front Assembly Replacement, Front Assembly: passo 1, immagine 3 di 3
    • Open the small latch on the left side of the device by lifting gently with your finger, exposing the SIM card and microSD card slots.
    • If either of these cards are present, remove them to prevent damaging them while taking apart the phone. Our device does not have either.
    • Close the latch once the two cards are removed.
  2. Motorola Droid RAZR M Front Assembly Replacement: passo 2, immagine 1 di 3 Motorola Droid RAZR M Front Assembly Replacement: passo 2, immagine 2 di 3 Motorola Droid RAZR M Front Assembly Replacement: passo 2, immagine 3 di 3
    • Remove the six 4mm T3 Torx screws. There are 3 on each side of the device.
  3. Motorola Droid RAZR M Front Assembly Replacement: passo 3, immagine 1 di 3 Motorola Droid RAZR M Front Assembly Replacement: passo 3, immagine 2 di 3 Motorola Droid RAZR M Front Assembly Replacement: passo 3, immagine 3 di 3
    • Run the plastic opening tool under the bottom edge of the phone to detach the small plastic cover below the Verizon logo.
    • It will take some force to remove this piece. Work around the bottom corners to unlatch the two hooks holding the piece in place.
    • The small plastic hooks can break during removal. Be careful that you don't damage them, but it will take some force to get them undone.
    • Once the plastic cover is detached, pull the piece away with your fingers.
  4. Motorola Droid RAZR M Front Assembly Replacement: passo 4, immagine 1 di 2 Motorola Droid RAZR M Front Assembly Replacement: passo 4, immagine 2 di 2
    • Remove the three T4 Torx screws. There are three at the bottom of the device.
  5. Motorola Droid RAZR M Front Assembly Replacement: passo 5, immagine 1 di 3 Motorola Droid RAZR M Front Assembly Replacement: passo 5, immagine 2 di 3 Motorola Droid RAZR M Front Assembly Replacement: passo 5, immagine 3 di 3
    • Using the plastic opening tool, peel away the silver Motorola plate at the top of the phone. There is a fair amount of adhesive underneath, so you may have to pry it from a few different angles.
    • As soon as you can get your finger underneath, pull away the silver plate.
  6. Motorola Droid RAZR M Front Assembly Replacement: passo 6, immagine 1 di 2 Motorola Droid RAZR M Front Assembly Replacement: passo 6, immagine 2 di 2
    • Remove the two 7mm T4 Torx screws at the top of the device.
  7. Motorola Droid RAZR M Front Assembly Replacement: passo 7, immagine 1 di 3 Motorola Droid RAZR M Front Assembly Replacement: passo 7, immagine 2 di 3 Motorola Droid RAZR M Front Assembly Replacement: passo 7, immagine 3 di 3
    • When you detach the front from the back, don't pull the two pieces entirely apart. There is a flat orange wire that connects the two pieces that will be disconnected in the next step.
    • Snap apart the two internal clips located on the top corners of the device, and the two clips in the bottom corners.
    • Run the plastic opening tool around the edge of the entire device to pry apart the front of the phone from the back.
    • There is a small black plastic piece located at the bottom of the front assembly. Do not worry if the strip falls off; just simply snap it back on and proceed.
  8. Motorola Droid RAZR M Front Assembly Replacement: passo 8, immagine 1 di 3 Motorola Droid RAZR M Front Assembly Replacement: passo 8, immagine 2 di 3 Motorola Droid RAZR M Front Assembly Replacement: passo 8, immagine 3 di 3
    • Like a clamshell, slowly open the device from the top. Open the remainder of the device slowly while being mindful of the flat orange wire that connects the motherboard to the front assembly.
    • Undo the snap connection in the lower left corner by inserting the plastic opening tool under the end of the orange wire connected to the motherboard. Lift gently.
    • Once the snap connection is undone, pull apart the front assembly from the rest of the phone.
Conclusione
Altre 4 persone hanno completato questa guida.
Ethan Look
Membro da: 04/21/15
498 Reputazione
3 Guide realizzate
Cal Poly, Team 15-1, Amido Spring 2015 Membro di Cal Poly, Team 15-1, Amido Spring 2015
CPSU-AMIDO-S15S15G1
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,090
