Salta al contenuto principale
Motorola Droid Pro Screen Replacement
Cosa ti serve
  1. Motorola Droid Pro Screen Replacement, SD Card/SIM Card PCB Board: passo 1, immagine 1 di 2 Motorola Droid Pro Screen Replacement, SD Card/SIM Card PCB Board: passo 1, immagine 2 di 2
    • Remove the back cover and battery by using the thumb tabs.
  2. Motorola Droid Pro Screen Replacement: passo 2, immagine 1 di 1
    • Unscrew the 8 back panel screws using the T4 Torx screwdriver.
  3. Motorola Droid Pro Screen Replacement: passo 3, immagine 1 di 1
    • Use a spudger to open the phone along the sides between the back panel and the chrome trim.
    • It is held together by small clips that lock in. You may have to use a little force to unlock them.
    • Go around on all sides then pull the back panel off.
  4. Motorola Droid Pro Screen Replacement: passo 4, immagine 1 di 2 Motorola Droid Pro Screen Replacement: passo 4, immagine 2 di 2
    • Gently lift the SD & SIM card board (PCB) as shown in the following pictures.
    • This will expose the ribbon cable attached to the board and another ribbon cable for the mother board. Remove them both using the spudger.
    • Once the small one is removed the small board can be pulled off.
  5. Motorola Droid Pro Screen Replacement, Screen: passo 5, immagine 1 di 1
    • Unscrew the 6 screws using the T5 Torx screwdriver.
  6. Motorola Droid Pro Screen Replacement: passo 6, immagine 1 di 1
    • Unlock the ribbon cable and then you can pull the screen out.
    • When replacing screen make sure you lock the ribbon cable back in place.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 288
