Introduzione
Before continuing make sure you power down your device and work in a clean area. Also wear a static band to prevent damages to your device.
Cosa ti serve
Remove the back cover using the thumb tab located on the bottom of the phone.
Using a T4 Torx driver, remove the eight 4 mm back panel screws.
Use your plastic opening tool to disconnect the motherboard/keyboard ribbon cable.
Unlock the screen's ribbon cable.
To remove the screen, you have to flip the phone over and let it fall out slowly into your hand. Be careful not to put any tension on the ribbon cable.
Then pull the screen away from the ribbon cable connector and it will slide out easily. Do not use excessive force.
Disconnect the last cable.
Then use a plastic opening tool to pop out the keyboard.
Altre 2 persone hanno completato questa guida.
