Salta al contenuto principale
Motorola Droid Pro Camera Replacement
Cosa ti serve
  1. Motorola Droid Pro Camera Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the back cover using the thumb tab located on the bottom of the phone.
  2. Motorola Droid Pro Camera Replacement: passo 2, immagine 1 di 2 Motorola Droid Pro Camera Replacement: passo 2, immagine 2 di 2
    • Remove the battery using the thumb tab.
  3. Motorola Droid Pro Camera Replacement, SD Card/SIM Card PCB Board: passo 3, immagine 1 di 2 Motorola Droid Pro Camera Replacement, SD Card/SIM Card PCB Board: passo 3, immagine 2 di 2
    • Using a T4 Torx driver, remove the eight 4 mm back panel screws.
  4. Motorola Droid Pro Camera Replacement: passo 4, immagine 1 di 3 Motorola Droid Pro Camera Replacement: passo 4, immagine 2 di 3 Motorola Droid Pro Camera Replacement: passo 4, immagine 3 di 3
    • Use a plastic opening tool to open the phone along the sides between the front panel and the chrome trim.
    • It is held together by small clips that lock in. You may have to use extra force to unlock them.
    • Go around on all sides of the phone, unlocking the clips. Then pull the back panel off.
  5. Motorola Droid Pro Camera Replacement: passo 5, immagine 1 di 2 Motorola Droid Pro Camera Replacement: passo 5, immagine 2 di 2
    • Gently lift the SD & SIM card board (PCB) as shown.
    • There is a ribbon cable attached underneath. Gently pull the PCB board away from the phone and it will detach easily.
  6. Motorola Droid Pro Camera Replacement, Motherboard: passo 6, immagine 1 di 2 Motorola Droid Pro Camera Replacement, Motherboard: passo 6, immagine 2 di 2
    • Use your plastic opening tool to disconnect the motherboard/keyboard ribbon cable.
    • There are small tabs on the side of the connectors to wedge your tool under.
  7. Motorola Droid Pro Camera Replacement: passo 7, immagine 1 di 2 Motorola Droid Pro Camera Replacement: passo 7, immagine 2 di 2
    • Use your plastic opening tool to disconnect the two ribbon cables at the top of the phone.
  8. Motorola Droid Pro Camera Replacement: passo 8, immagine 1 di 2 Motorola Droid Pro Camera Replacement: passo 8, immagine 2 di 2
    • Disconnect the 2nd keyboard connector from the motherboard and remove it from its side holders.
    • This cable is fragile so be careful when disconnecting and moving it around.
  9. Motorola Droid Pro Camera Replacement: passo 9, immagine 1 di 1
    • Use a T5 Torx Screwdriver to unscrew the 2mm screw.
  10. Motorola Droid Pro Camera Replacement: passo 10, immagine 1 di 3 Motorola Droid Pro Camera Replacement: passo 10, immagine 2 di 3 Motorola Droid Pro Camera Replacement: passo 10, immagine 3 di 3
    • Remove the camera's rubber seal by pulling it off. It is not connected to anything.
  11. Motorola Droid Pro Camera Replacement: passo 11, immagine 1 di 2 Motorola Droid Pro Camera Replacement: passo 11, immagine 2 di 2
    • To remove the motherboard, pull it to the side. The camera that is connected to the motherboard does not pull straight up and out from its holder.
  12. Motorola Droid Pro Camera Replacement, Camera: passo 12, immagine 1 di 3 Motorola Droid Pro Camera Replacement, Camera: passo 12, immagine 2 di 3 Motorola Droid Pro Camera Replacement, Camera: passo 12, immagine 3 di 3
    • The camera is located on the back side of PCB board.
    • Flip the board over and you will see that the camera is connected by a ribbon cable.
    • Unlock the cable by using a plastic remover tool then pull the camera out.
    • Insert the new camera and re lock the ribbon cable.
    • Do not use excessive force and make sure the cameras ribbon cable gets properly re seated.
Conclusione
Altre 2 persone hanno completato questa guida.
UMass Dartmouth, Team 1-6, Miles Fall 2015 Membro di UMass Dartmouth, Team 1-6, Miles Fall 2015
UMASSD-MILES-F15S1G6
3 Membri
12 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 9
Tutti i Tempi: 256
