Salta al contenuto principale
Motorola Droid MAXX 2 Rear Camera Replacement
Cosa ti serve
  1. Motorola Droid MAXX 2 Rear Camera Replacement, Battery: passo 1, immagine 1 di 1
    • Insert a small pointed object into the hole on the sim card tray to eject the tray from the phone.
  2. Motorola Droid MAXX 2 Rear Camera Replacement: passo 2, immagine 1 di 1
    • Pull the sim card tray up out of the phone
  3. Motorola Droid MAXX 2 Rear Camera Replacement: passo 3, immagine 1 di 2 Motorola Droid MAXX 2 Rear Camera Replacement: passo 3, immagine 2 di 2
    • Wedge your thumb into the indent located on the bottom left corner of the back cover and pull up to remove the back cover.
  4. Motorola Droid MAXX 2 Rear Camera Replacement: passo 4, immagine 1 di 1
    • Remove the seventeen 3.2mm Torx T4 screws from the mid-frame.
    • These may be T3 screws. If you are having trouble unscrewing these, stop and try a T3 bit.
  5. Motorola Droid MAXX 2 Rear Camera Replacement: passo 5, immagine 1 di 1
    • Pull the mid-frame off of the phone.
    • Keep track of the on/off and volume buttons when you take the phone apart because they are likely to fall out when the halves are separated.
  6. Motorola Droid MAXX 2 Rear Camera Replacement: passo 6, immagine 1 di 3 Motorola Droid MAXX 2 Rear Camera Replacement: passo 6, immagine 2 di 3 Motorola Droid MAXX 2 Rear Camera Replacement: passo 6, immagine 3 di 3
    • Remove the static tape covering the two connectors.
    • Use a spudger to disconnect the battery cables from the motherboard.
    • If battery has adhesive, use heat gun for one to two minutes to loosen it. Be careful of the points outlined in red when prying it up. Use guitar picks or a spudger to gently lift the battery and separate the adhesive.
  7. Motorola Droid MAXX 2 Rear Camera Replacement: passo 7, immagine 1 di 1
    • Remove the disconnected battery from the phone.
  8. Motorola Droid MAXX 2 Rear Camera Replacement, Rear Camera: passo 8, immagine 1 di 1
    • Peel up orange adhesive that covers the ZIF connector.
  9. Motorola Droid MAXX 2 Rear Camera Replacement: passo 9, immagine 1 di 1
    • Use a spudger to lift up the black tab on the ZIF connector.
    • Remove the camera.
Conclusione
Baylor, Team S3-G4, Williams Spring 2018 Membro di Baylor, Team S3-G4, Williams Spring 2018
BU-WILLIAMS-S18S3G4
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 6
Tutti i Tempi: 305
