Introduzione
The SIM card stores important information on your phone. You should handle it with care when you are using this guide.
You will need to remove several torx head screws. Make sure to use the correct type.
Cosa ti serve
Insert the rear cover removal tool, or a paper clip, in the hole near the back camera lens.
Slide the cover down to remove.
Using tweezers or your finger, lift the rubber SIM card cover to expose the card itself.
While holding the cover open, use your finger to press and slide out the SIM card.
Follow the same steps in the opposite order to install the new SIM card.
