Salta al contenuto principale
Motorola Droid 4 Rear Bezel Replacement
Cosa ti serve
  1. Motorola Droid 4 Rear Bezel Replacement, Removing Rear Panel: passo 1, immagine 1 di 3 Motorola Droid 4 Rear Bezel Replacement, Removing Rear Panel: passo 1, immagine 2 di 3 Motorola Droid 4 Rear Bezel Replacement, Removing Rear Panel: passo 1, immagine 3 di 3
    • Insert the rear cover removal tool, or a paper clip, in the hole near the back camera lens.
    • Slide the cover down to remove.
  2. Motorola Droid 4 Rear Bezel Replacement, Battery: passo 2, immagine 1 di 1
    • Remove the sticker on the rear compartment to reveal the battery.
    • Hold the battery with your thumb while removing the sticker or you might end up ripping the battery out of the phone, damaging the flex cable.
  3. Motorola Droid 4 Rear Bezel Replacement: passo 3, immagine 1 di 2 Motorola Droid 4 Rear Bezel Replacement: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    T5 Torx Screwdriver
    $5.49
    Compra
    • Use the T5 Torx Screwdriver to remove both 2.5 mm screws from the battery cable.
    • Use the Spudger to unstick the battery.
    • It's difficult to remove the battery without a pry tool like the spudger because of the strong adhesive. If you try removing it with just your fingers, the battery may bend.
  4. Motorola Droid 4 Rear Bezel Replacement, Camera Cover Removal: passo 4, immagine 1 di 3 Motorola Droid 4 Rear Bezel Replacement, Camera Cover Removal: passo 4, immagine 2 di 3 Motorola Droid 4 Rear Bezel Replacement, Camera Cover Removal: passo 4, immagine 3 di 3
    • Using the blue plastic opening tool, pry off the thin plastic camera cover.
    • The plastic cover is fragile, so proceed carefully.
  5. Motorola Droid 4 Rear Bezel Replacement, Remove Screws: passo 5, immagine 1 di 2 Motorola Droid 4 Rear Bezel Replacement, Remove Screws: passo 5, immagine 2 di 2
    • Remove the four screws, indicated by the red circles, with the screwdriver and T5 Torx bit.
    • The screws are philips 2.5mm. One screw is a different color (silver) from the others (black).
  6. Motorola Droid 4 Rear Bezel Replacement, Remove Bezel: passo 6, immagine 1 di 3 Motorola Droid 4 Rear Bezel Replacement, Remove Bezel: passo 6, immagine 2 di 3 Motorola Droid 4 Rear Bezel Replacement, Remove Bezel: passo 6, immagine 3 di 3
    • Insert the spudger between the rear bezel and the main housing.
    • The bezel is fragile, so proceed carefully.
    • Slide the spudger around all sides of the phone to separate the bezel from the housing.
    • Pry the bezel free.
    • Be careful of the adhesive that holds the bezel to the main housing. Prying too hard may damage your phone.
Conclusione
Cheriann
Membro da: 09/23/14
156 Reputazione
1 Guida realizzata
USF Tampa, Team 5-1, Mcgee Fall 2014 Membro di USF Tampa, Team 5-1, Mcgee Fall 2014
USFT-MCGEE-F14S5G1
5 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 515
