Salta al contenuto principale
Motorola Droid 2 Speaker Replacement
Cosa ti serve
  1. Motorola Droid 2 Speaker Replacement, Battery: passo 1, immagine 1 di 3 Motorola Droid 2 Speaker Replacement, Battery: passo 1, immagine 2 di 3 Motorola Droid 2 Speaker Replacement, Battery: passo 1, immagine 3 di 3
    • Slide the battery cover toward the bottom edge of the phone.
    • Remove the battery cover from the rear of the phone.
  2. Motorola Droid 2 Speaker Replacement: passo 2, immagine 1 di 2 Motorola Droid 2 Speaker Replacement: passo 2, immagine 2 di 2
    • Lift the battery out of the Droid 2 from the edge closest to the bottom of the phone.
    • Remove the battery from the Droid 2.
  3. Motorola Droid 2 Speaker Replacement, Rear Case: passo 3, immagine 1 di 2 Motorola Droid 2 Speaker Replacement, Rear Case: passo 3, immagine 2 di 2
    • Using the tip of a spudger, peel up one corner of the silver ribbon below the battery compartment.
    • Peel the ribbon off the phone.
  4. Motorola Droid 2 Speaker Replacement: passo 4, immagine 1 di 1
    • Insert the flat end of a spudger and pry the plastic camera cover up off the phone.
    • The thin plastic cover is attached to the phone with an adhesive. Work slowly and carefully.
  5. Motorola Droid 2 Speaker Replacement: passo 5, immagine 1 di 1
    • Use the tip of a spudger to remove the camera bezel stuck to the rear case.
  6. Motorola Droid 2 Speaker Replacement: passo 6, immagine 1 di 1
    • Remove the seven 5.5 mm T5 Torx screws securing the rear case to the inner case.
  7. Motorola Droid 2 Speaker Replacement: passo 7, immagine 1 di 1
    • Insert the flat end of a spudger and pry downwards to release the plastic tab holding the rear case to the motherboard screw.
  8. Motorola Droid 2 Speaker Replacement: passo 8, immagine 1 di 1
    • Gently insert a spudger between the rear case and front case at the top of the phone, near the audio jack.
    • Carefully pry the top edge of the rear case up from the rest of the phone.
  9. Motorola Droid 2 Speaker Replacement: passo 9, immagine 1 di 2 Motorola Droid 2 Speaker Replacement: passo 9, immagine 2 di 2
    • With the spudger still inserted between the rear case and front case, slide the spudger along the right edge of the device, moving toward the bottom, prying as you go.
    • Continue prying along the bottom edge of the device from right to left, freeing it from the front panel.
  10. Motorola Droid 2 Speaker Replacement: passo 10, immagine 1 di 2 Motorola Droid 2 Speaker Replacement: passo 10, immagine 2 di 2
    • Continue prying the rear case from the front case along the left side, moving from bottom to top.
    • Lift the rear case up out of the phone.
    • At this point, the button covers on the side of the phone are free and may fall out if you tip the phone upside down.
  11. Motorola Droid 2 Speaker Replacement, Speaker: passo 11, immagine 1 di 1
    • Carefully lift the speaker/antenna assembly up and out of the phone.
    • If you are re-assembling your phone, insert any power, camera, or volume buttons that may have fallen out at this point.
Conclusione
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 6,928
