Salta al contenuto principale
Motorola Defy XT Camera Replacement
Cosa ti serve
  1. Motorola Defy XT Camera Replacement, Camera: passo 1, immagine 1 di 1
    • Locate the opening on the corner of the Motorola Defy XT mobile phone.
    • Wedge the Plastic Opening Tool between the back cover and the body of the phone.
  2. Motorola Defy XT Camera Replacement: passo 2, immagine 1 di 1
    • Once wedged in the opening, gently pry around the phone until back cover lifts off.
  3. Motorola Defy XT Camera Replacement: passo 3, immagine 1 di 1
    • Remove the back cover and locate the battery.
    • Insert the opening tool beneath the battery and lightly push upward.
  4. Motorola Defy XT Camera Replacement: passo 4, immagine 1 di 1
    • Locate the SD card beneath the plastic cover in the corner.
    • Use a Plastic Opening Tool to hook the edge of the SD card
  5. Motorola Defy XT Camera Replacement: passo 5, immagine 1 di 1
    • Push the SD card straight out.
  6. Motorola Defy XT Camera Replacement: passo 6, immagine 1 di 1
    • Use the T4 Torque Driver to remove all 6 of the 3mm diameter screws on the outside edges of the phone.
  7. Motorola Defy XT Camera Replacement: passo 7, immagine 1 di 1
    • Wedge the Plastic Opening Tool under the inner side of the volume buttons.
    • Pop the volume buttons out of the phone.
  8. Motorola Defy XT Camera Replacement: passo 8, immagine 1 di 1
    • Locate the base of the motherboard.
    • Slide the Plastic Opening Tool along the base of the motherboard to separate it from the phone.
    • Gently guide the two pieces apart with upward motion.
    • Caution: Do not damage the ribbon that is holding both pieces
  9. Motorola Defy XT Camera Replacement: passo 9, immagine 1 di 1
    • Disconnect the ribbon from the frame.
    • Remove the screen.
  10. Motorola Defy XT Camera Replacement: passo 10, immagine 1 di 1
    • Flip the mother board over.
    • Locate the base of the ribbon cable.
    • Pull straight outward using the Plastic Opening Tool.
    • Disconnect the ribbon cable connecting the display to the logic board
  11. Motorola Defy XT Camera Replacement: passo 11, immagine 1 di 1
    • Pull the two halves of the device apart to disconnect the second (wider) ribbon connector.
    • Note: The ribbon connector is bonded to the logic board with adhesive, simply pull it to remove it completely.
  12. Motorola Defy XT Camera Replacement: passo 12, immagine 1 di 1
    • Use the Plastic Opening Tool to disconnect the camera from the logic board.
Conclusione
Mustapha Nadri
Membro da: 04/19/13
1 Reputazione
1 Guida realizzata
Cal Poly, Team 2-22, Maness Spring 2013 Membro di Cal Poly, Team 2-22, Maness Spring 2013
CPSU-MANESS-S13S2G22
3 Membri
8 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,003
