Salta al contenuto principale
Motorola Cliq LCD Screen Replacement
Cosa ti serve
  1. Motorola Cliq LCD Screen Replacement, Battery: passo 1, immagine 1 di 2 Motorola Cliq LCD Screen Replacement, Battery: passo 1, immagine 2 di 2
    • Turning over your phone, place two fingers on the back cover and apply pressure away from the camera to slide the back cover off.
  2. Motorola Cliq LCD Screen Replacement: passo 2, immagine 1 di 2 Motorola Cliq LCD Screen Replacement: passo 2, immagine 2 di 2
    • Pinch the battery pull tab located below the camera, pull it upwards, and remove the battery.
    • The pull tab may be tucked under the battery.
  3. Motorola Cliq LCD Screen Replacement, Rear Casing: passo 3, immagine 1 di 3 Motorola Cliq LCD Screen Replacement, Rear Casing: passo 3, immagine 2 di 3 Motorola Cliq LCD Screen Replacement, Rear Casing: passo 3, immagine 3 di 3
    • Wedge a plastic opening tool behind the panel covering the camera, pry it up, and remove it using your fingers.
    • The panel is held down by adhesive and may require you to wedge and pry the right side of the panel before it can be easily removed.
  4. Motorola Cliq LCD Screen Replacement: passo 4, immagine 1 di 1
    • Remove the six 4.0 mm T4 Torx screws which line the edge of the back of the phone.
  5. Motorola Cliq LCD Screen Replacement: passo 5, immagine 1 di 3 Motorola Cliq LCD Screen Replacement: passo 5, immagine 2 di 3 Motorola Cliq LCD Screen Replacement: passo 5, immagine 3 di 3
    • Turn the phone over and slide out the keyboard.
    • Wedge a plastic opening tool where the keyboard meets the back casing of the phone next to the headphone jack.
    • Carefully pry open the back casing along the keyboard's edge until at least two corners of the back casing are separated from the keyboard.
    • Do not fully separate the rear panel from the phone. A cable is connecting the two parts together.
  6. Motorola Cliq LCD Screen Replacement: passo 6, immagine 1 di 1
    • Carefully separate the back casing from the rest of the phone.
  7. Motorola Cliq LCD Screen Replacement: passo 7, immagine 1 di 2 Motorola Cliq LCD Screen Replacement: passo 7, immagine 2 di 2
    • Gently pry ZIF connector upwards using the flat end of a spudger tool.
    • The ZIF connector is glued down. Be gentle! Ripping it off or breaking it will make your phone inoperable.
    • You may need adhesive to keep your power cable in place when reassembling your phone.
  8. Motorola Cliq LCD Screen Replacement: passo 8, immagine 1 di 3 Motorola Cliq LCD Screen Replacement: passo 8, immagine 2 di 3 Motorola Cliq LCD Screen Replacement: passo 8, immagine 3 di 3
    • Press your thumb against the orange power cable and pull it down slowly to disconnect the power cable from the bottom of the keyboard.
    • The rear casing and the rest of the phone should now be completely separated.
  9. Motorola Cliq LCD Screen Replacement, Motherboard: passo 9, immagine 1 di 2 Motorola Cliq LCD Screen Replacement, Motherboard: passo 9, immagine 2 di 2
    • Wedge the plastic opening tool underneath the black display connector and pry it off its socket on the motherboard.
  10. Motorola Cliq LCD Screen Replacement: passo 10, immagine 1 di 2 Motorola Cliq LCD Screen Replacement: passo 10, immagine 2 di 2
    • Pry the orange keyboard connector from its socket on the motherboard using the edge of the plastic opening tool.
  11. Motorola Cliq LCD Screen Replacement: passo 11, immagine 1 di 3 Motorola Cliq LCD Screen Replacement: passo 11, immagine 2 di 3 Motorola Cliq LCD Screen Replacement: passo 11, immagine 3 di 3
    • Carefully grab the sides of the motherboard with your fingers and remove it from the phone.
  12. Motorola Cliq LCD Screen Replacement, LCD Shield Plate: passo 12, immagine 1 di 1
    • Remove the ten 3.0 mm T4 Torx screws near the black display cable.
  13. Motorola Cliq LCD Screen Replacement: passo 13, immagine 1 di 3 Motorola Cliq LCD Screen Replacement: passo 13, immagine 2 di 3 Motorola Cliq LCD Screen Replacement: passo 13, immagine 3 di 3
    • Orient the phone so that the edge closest to the camera points towards you and slide out the keyboard.
    • Wedge the tip of a spudger between the keyboard and the display assembly below the camera.
    • With steady pressure, pry the keyboard away from the display assembly.
    • The keyboard and display assembly are glued together, so expect some resistance.
    • Do not completely separate the keyboard and display assembly because the display flex cable still connects them.
  14. Motorola Cliq LCD Screen Replacement: passo 14, immagine 1 di 3 Motorola Cliq LCD Screen Replacement: passo 14, immagine 2 di 3 Motorola Cliq LCD Screen Replacement: passo 14, immagine 3 di 3
    • Grab the display flex cable and gently push it through the notch it is coming out of.
  15. Motorola Cliq LCD Screen Replacement: passo 15, immagine 1 di 3 Motorola Cliq LCD Screen Replacement: passo 15, immagine 2 di 3 Motorola Cliq LCD Screen Replacement: passo 15, immagine 3 di 3
    • Wedge a plastic opening tool underneath one of the metal panels on the underside of the display assembly.
    • Pry upwards and remove the metal panel.
    • Repeat this step for the second metal panel located on the opposite side of the phone.
  16. Motorola Cliq LCD Screen Replacement: passo 16, immagine 1 di 1
    • Remove the four 3.0 mm T4 Torx screws at the corners of the phone.
  17. Motorola Cliq LCD Screen Replacement: passo 17, immagine 1 di 3 Motorola Cliq LCD Screen Replacement: passo 17, immagine 2 di 3 Motorola Cliq LCD Screen Replacement: passo 17, immagine 3 di 3
    • Wedge a plastic opening tool between the edge and the black pastic cover on the underside of the display assembly.
    • Run the plastic opening tool along the edges to separate the black plastic cover from the display assembly.
    • Remove the black plastic cover.
  18. Motorola Cliq LCD Screen Replacement: passo 18, immagine 1 di 1
    • Remove the six 3.0 mm T4 Torx screws that align on the phone's sides.
  19. Motorola Cliq LCD Screen Replacement: passo 19, immagine 1 di 2 Motorola Cliq LCD Screen Replacement: passo 19, immagine 2 di 2
    • Insert a plastic opening tool between the LCD shield plate and a corner of the keyboard slider plate.
    • Pry apart the keyboard slider plate and LCD shield plate.
    • Do not completely separate them: the keyboard slider plate is still connected to the LCD shield plate via the display flex cable.
  20. Motorola Cliq LCD Screen Replacement: passo 20, immagine 1 di 2 Motorola Cliq LCD Screen Replacement: passo 20, immagine 2 di 2
    • Pry the display flex cable from its connector on the LCD shield plate with a plastic opening tool.
    • Separate the display flex cable from the LCD cover plate.
  21. Motorola Cliq LCD Screen Replacement, LCD Screen: passo 21, immagine 1 di 2 Motorola Cliq LCD Screen Replacement, LCD Screen: passo 21, immagine 2 di 2
    • Pry off the flex cable located at the top right of the display assembly using the flat end of a spudger.
  22. Motorola Cliq LCD Screen Replacement: passo 22, immagine 1 di 2 Motorola Cliq LCD Screen Replacement: passo 22, immagine 2 di 2
    • Turn the display on its side.
    • Carefully tilt the screen of the display until the digitizer starts to fall out.
    • Do not completely separate the digitizer just yet: it is still connected to the LCD case.
  23. Motorola Cliq LCD Screen Replacement: passo 23, immagine 1 di 3 Motorola Cliq LCD Screen Replacement: passo 23, immagine 2 di 3 Motorola Cliq LCD Screen Replacement: passo 23, immagine 3 di 3
    • With the digitizer held between two fingers, gently pull it away from the bottom of the phone until the digitizer flex cable has been completely removed from its socket.
    • Remove the digitizer.
Conclusione
Altre 3 persone hanno completato questa guida.
Tony Tran
Membro da: 04/14/13
69 Reputazione
8 Guide realizzate
Cal Poly, Team 10-42, Amido Spring 2013 Membro di Cal Poly, Team 10-42, Amido Spring 2013
CPSU-AMIDO-S13S10G42
4 Membri
16 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,198
