Salta al contenuto principale
Motorola California Mobile Phone Rear Casing Replacement
Cosa ti serve
  1. Motorola California Mobile Phone Rear Casing Replacement, Rear Casing: passo 1, immagine 1 di 1
    • Remove the battery by sliding it down the rails to which it is connected.
  2. Motorola California Mobile Phone Rear Casing Replacement: passo 2, immagine 1 di 1
    • Find a flat head or Phillips head screwdriver.
    • Insert the screwdriver into the holes in the plastic rod connecting the key pad guard to the rear casing.
    • Use the screwdriver to push the rods towards each other until they click out of their locked position.
    • Note: This may require a large amount of force.
  3. Motorola California Mobile Phone Rear Casing Replacement: passo 3, immagine 1 di 1
    • Slide off the antenna guard and locate the four clips on the exterior of the rear casing.
    • Simultaneously push the clips outward while lifting the old rear casing away from the rest of the device.
  4. Motorola California Mobile Phone Rear Casing Replacement: passo 4, immagine 1 di 1
    • Locate the four holes on the new rear casing.
    • Align the holes in the new rear casing with the clips attached the to front casing.
    • Simultaneously insert all four clips.
    • Push down firmly until you hear the clips click into place.
  5. Motorola California Mobile Phone Rear Casing Replacement: passo 5, immagine 1 di 1
    • Find a thin and sturdy screwdriver.
    • Insert the screwdriver into the holes in the plastic rod connecting the new key pad guard to the rear casing.
    • Use the screwdriver to push the rods away from each other until they click into their locked position.
Conclusione
Andrew Lam
Membro da: 04/17/12
35 Reputazione
4 Guide realizzate
Cal Poly, Team 9-46, Regan Spring 2012 Membro di Cal Poly, Team 9-46, Regan Spring 2012
CPSU-REGAN-S12S9G46
5 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 976
