Salta al contenuto principale
Motorola California Mobile Phone Antenna Replacement
Cosa ti serve
  1. Motorola California Mobile Phone Antenna Replacement, Antenna: passo 1, immagine 1 di 1
    • Remove the battery by sliding it down the rails to which it is connected.
  2. Motorola California Mobile Phone Antenna Replacement: passo 2, immagine 1 di 1
    • Insert the Phillips 00 screwdriver into the holes that connect the key pad guard to the rear casing in the plastic rod.
    • The following step may require a substantial amount of force.
    • Use the screwdriver to push the rods towards each other until they click out of their locked positions.
  3. Motorola California Mobile Phone Antenna Replacement: passo 3, immagine 1 di 1
    • Slide off the antenna guard and locate the four clips on the exterior of the rear casing.
    • Push the clips outward while simultaneously lifting the rear casing and keyguard away from the front casing.
  4. Motorola California Mobile Phone Antenna Replacement: passo 4, immagine 1 di 1
    • Locate and unplug the black component of the current antenna from the motherboard.
    • Under the black component there should be a blue component.
    • Unscrew the blue component in order to free the antenna.
  5. Motorola California Mobile Phone Antenna Replacement: passo 5, immagine 1 di 1
    • Slide the antenna out of the green tubing.
    • Slide the green tubing out of its hole.
  6. Motorola California Mobile Phone Antenna Replacement: passo 6, immagine 1 di 1
    • Insert the new green tubing into the corresponding slot.
  7. Motorola California Mobile Phone Antenna Replacement: passo 7, immagine 1 di 1
    • Insert the new antenna into the green tubing.
  8. Motorola California Mobile Phone Antenna Replacement: passo 8, immagine 1 di 1
    • Screw the blue piece of the antenna into the threaded hole on the motherboard until it is tight.
  9. Motorola California Mobile Phone Antenna Replacement: passo 9, immagine 1 di 1
    • Align the protruding wire on the black component with the corresponding hole on the motherboard.
    • Push the wire into the hole.
  10. Motorola California Mobile Phone Antenna Replacement: passo 10, immagine 1 di 1
    • Reverse the instructions from Step 2 to re-install the keypad guard and rear casing onto the device.
  11. Motorola California Mobile Phone Antenna Replacement: passo 11, immagine 1 di 1
    • Push down on the antenna guard until it clicks into place.
Conclusione
Andrew Lam
Membro da: 04/17/12
35 Reputazione
4 Guide realizzate
Cal Poly, Team 9-46, Regan Spring 2012 Membro di Cal Poly, Team 9-46, Regan Spring 2012
CPSU-REGAN-S12S9G46
5 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,845
