Introduzione
Use this guide to replace the rubber keypad on your Motorola C350.
Strumenti
Nessun attrezzo richiesto.
Parti
Nessuna parte richiesta.
  1. Use your finger to press the button and free the device rear case. You may have to force it a bit more to free its bottom if you open it for the first time.
    • Use your finger to press the button and free the device rear case.
    • You may have to force it a bit more to free its bottom if you open it for the first time.
  2. slide the black button to free the battery so you can grab it with your other hand.
    • slide the black button to free the battery so you can grab it with your other hand.
  3. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  4. You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components. You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components.
    • You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components.
  5. Use your thumb to gently peel the keyboard off the front case.
    • Use your thumb to gently peel the keyboard off the front case.
    • Be careful, the plastic on which the keyboard is stuck is pretty fragile.
Conclusione
Vincent Monteil
Membro da: 06/07/2013
6.229 Reputazione
19 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 245
