Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
Use this guide to replace the LCD in your Motorola C350.
  1. Use your finger to press the button and free the device rear case. You may have to force it a bit more to free its bottom if you open it for the first time.
    • Use your finger to press the button and free the device rear case.
    • You may have to force it a bit more to free its bottom if you open it for the first time.
  2. slide the black button to free the battery so you can grab it with your other hand.
    • slide the black button to free the battery so you can grab it with your other hand.
  3. You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components. You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components.
    • You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components.
  4. Kit per Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Remove the 4 T6 Torx screws Remove the 4 T6 Torx screws
    • Remove the 4 T6 Torx screws
  6. Use a metal spudger to pell off the four metal clips and separate the motherboard and keyboard from the main plastic part. Use a metal spudger to pell off the four metal clips and separate the motherboard and keyboard from the main plastic part.
    • Use a metal spudger to pell off the four metal clips and separate the motherboard and keyboard from the main plastic part.
  7. The last thing you need to doto access the Logic Board is to separate the Keyboard/Screen block just taking apart with your fingers.
    • The last thing you need to doto access the Logic Board is to separate the Keyboard/Screen block just taking apart with your fingers.
  8. Remove the two small metal clips keeping the cables safe.
    • Remove the two small metal clips keeping the cables safe.
  9. Use a plastic spudger to pell off the two cables on the back side of the screen.
    • Use a plastic spudger to pell off the two cables on the back side of the screen.
    • There are two very small connectors. Take care of them and replace them if they incidentally fall.
  10. Use a plastic spudger to release the disconnected screen.
    • Use a plastic spudger to release the disconnected screen.
Conclusione
Vincent Monteil
Membro da: 06/07/2013
6.528 Reputazione
19 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 487
