Introduzione
This guide gives step-by-step instructions on repairing the speaker for a Motorola C290 cell phone.
Strumenti
Ricambi
Nessuna parte specificata.
Flip open your Motorola C290.
Remove rubber stoppers located around main screen using a push pin.
Use a Torx T6 Screwdriver to unscrew the four screws.
Use a plastic opening tool to pry open a gap between the top cover and the face of the phone.
Slide the plastic opening tool along gap and pry open case.
Remove top cover.
Unclip circuit attachments located on back of screen circuit board using a Spudger.
Insert the plastic opening tool between the metal screen components and the plastic frame at the corners.
Firmly pry the screen components from the frame with a twisting motion
Completely remove screen components from frame.
Insert spudger underneath the speaker.
Gently break the sticky seal between the phone case and speaker.
Lift the speaker off the phone case.
