Introduzione
This repair guide will show how to get to the logic board and replace it
Parti
Nessuna parte specificata.
Position Motorola C290 so that the back of the phone is facing up.
Apply pressure to the back cover while simultaneously sliding it downwards.
Unscrew antenna head from top of phone by twisting counterclockwise.
Pull the antenna out through the top hole and set aside.
Insert a Spudger (or pushpin) into the top notch of the rubber cover, located on the top of the phone.
Press down and rotate the Spudger lifting the rubber cover. Remove and set cover aside.
Using a T6 Torx screwdriver, unscrew all 5 screws and carefully set them aside.
