Salta al contenuto principale
Motorola C290 Keypad Replacement
Cosa ti serve
  1. Motorola C290 Keypad Replacement, Battery: passo 1, immagine 1 di 2 Motorola C290 Keypad Replacement, Battery: passo 1, immagine 2 di 2
    • Position Motorola C290 so that the back of the phone is facing up.
    • Apply pressure to the back cover while simultaneously sliding it downwards.
    • Note: It may be easiest to apply pressure to the ridges at the top of the back cover.
  2. Motorola C290 Keypad Replacement: passo 2, immagine 1 di 2 Motorola C290 Keypad Replacement: passo 2, immagine 2 di 2
    • Place your finger in the notch at the top of the battery.
    • Gently lift and pull out battery.
  3. Motorola C290 Keypad Replacement, Antenna: passo 3, immagine 1 di 3 Motorola C290 Keypad Replacement, Antenna: passo 3, immagine 2 di 3 Motorola C290 Keypad Replacement, Antenna: passo 3, immagine 3 di 3
    • Unscrew antenna head from top of phone by twisting counterclockwise.
    • Pull the antenna out through the top hole and set aside.
  4. Motorola C290 Keypad Replacement: passo 4, immagine 1 di 2 Motorola C290 Keypad Replacement: passo 4, immagine 2 di 2
    • Remove the plastic tube by lifting the bottom and pulling out towards yourself.
  5. Motorola C290 Keypad Replacement, Logic Board: passo 5, immagine 1 di 3 Motorola C290 Keypad Replacement, Logic Board: passo 5, immagine 2 di 3 Motorola C290 Keypad Replacement, Logic Board: passo 5, immagine 3 di 3
    • Insert a Spudger (or pushpin) into the top notch of the rubber cover, located on the top of the phone.
    • Press down and rotate the Spudger lifting the rubber cover. Remove and set cover aside.
    • Note: This will reveal a screw. Five screws should now be visible.
    • Using a T6 Torx screwdriver, unscrew all 5 screws and carefully set them aside.
  6. Motorola C290 Keypad Replacement: passo 6, immagine 1 di 2 Motorola C290 Keypad Replacement: passo 6, immagine 2 di 2
    • Insert the plastic opening tool in the groove at the top of the phone.
    • Rotate the tool to create an opening between the logic board cover and case.
  7. Motorola C290 Keypad Replacement: passo 7, immagine 1 di 2 Motorola C290 Keypad Replacement: passo 7, immagine 2 di 2
    • Slide the plastic opening tool along the groove, until the entire logic board cover has been opened.
    • Remove logic board cover and set aside.
  8. Motorola C290 Keypad Replacement: passo 8, immagine 1 di 1
    • Use the Spudger to detach the screen wire from the logic board.
  9. Motorola C290 Keypad Replacement: passo 9, immagine 1 di 3 Motorola C290 Keypad Replacement: passo 9, immagine 2 di 3 Motorola C290 Keypad Replacement: passo 9, immagine 3 di 3
    • Insert the Spudger into the slot on the top of the logic board.
    • Gently pry to loosen the top of the logic board.
    • Note: The logic board may initially seem glued to the phone. It is not glued but does require input of force to remove.
    • Grab the top of the logic board and pull at an angle to remove.
  10. Motorola C290 Keypad Replacement, Keypad: passo 10, immagine 1 di 1
    • Use your fingers to pull out the keypad.
    • Note: The keys and rubber backing are one piece.
Conclusione
Cal Poly, Team 24-28, Regan Spring 2010 Membro di Cal Poly, Team 24-28, Regan Spring 2010
CPSU-REGAN-S10S24G28
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,067
