Introduzione
This repair guide will show you how to remove the battery of the the Motorola C290.
Strumenti
Nessun attrezzo richiesto.
Parti
  1. Position Motorola C290 so that the back of the phone is facing up.
    • Position Motorola C290 so that the back of the phone is facing up.
    • Apply pressure to the back cover while simultaneously sliding it downwards.
    • Note: It may be easiest to apply pressure to the ridges at the top of the back cover.
  2. Place your finger in the notch at the top of the battery.
    • Place your finger in the notch at the top of the battery.
    • Gently lift and pull out battery.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 24-28, Regan Spring 2010 Membro di Cal Poly, Team 24-28, Regan Spring 2010
CPSU-REGAN-S10S24G28
4 Membri
6 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,062
