Salta al contenuto principale
Motorola C168 Front Panel Replacement
Cosa ti serve
  1. Motorola C168 Front Panel Replacement, Battery: passo 1, immagine 1 di 2 Motorola C168 Front Panel Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the phone so its back is facing you.
    • Press the release button on the back cover, while simultaneously pulling the cover down.
    • Remove the back cover.
  2. Motorola C168 Front Panel Replacement: passo 2, immagine 1 di 2 Motorola C168 Front Panel Replacement: passo 2, immagine 2 di 2
    • Pinch the sides of the bottom of the battery and pull upward.
  3. Motorola C168 Front Panel Replacement, SIM Card: passo 3, immagine 1 di 2 Motorola C168 Front Panel Replacement, SIM Card: passo 3, immagine 2 di 2
    • Press and slide the SIM card down.
    • Remove the SIM card.
  4. Motorola C168 Front Panel Replacement, Front Panel: passo 4, immagine 1 di 2 Motorola C168 Front Panel Replacement, Front Panel: passo 4, immagine 2 di 2
    • Orient the phone so its back is facing you.
    • Using a Torx T-4 screwdriver, carefully remove the 4 screws located at the corners of the phone.
    • Note: If you are using iFixit's screwdriver toolkit, look for the smallest T-screwbit.
  5. Motorola C168 Front Panel Replacement: passo 5, immagine 1 di 2 Motorola C168 Front Panel Replacement: passo 5, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Spudger
    $3.99
    • Lodge a spudger in between the front panel and the main frame of the phone.
    • Using a good amount of torque, pry the front panel from the phone.
Conclusione
Cal Poly, Team 12-40, Regan Spring 2012 Membro di Cal Poly, Team 12-40, Regan Spring 2012
CPSU-REGAN-S12S12G40
4 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,132
