Salta al contenuto principale
Motorola C139 SIM Card Replacement
Cosa ti serve
  1. Motorola C139 SIM Card Replacement, Battery: passo 1, immagine 1 di 3 Motorola C139 SIM Card Replacement, Battery: passo 1, immagine 2 di 3 Motorola C139 SIM Card Replacement, Battery: passo 1, immagine 3 di 3
    • Begin by flipping your phone over so that the back cover is facing up.
    • Apply force to the back cover and simultaneously slide the cover down.
    • Note: Applying pressure on the ridges will make it easier to remove the cover.
  2. Motorola C139 SIM Card Replacement: passo 2, immagine 1 di 3 Motorola C139 SIM Card Replacement: passo 2, immagine 2 di 3 Motorola C139 SIM Card Replacement: passo 2, immagine 3 di 3
    • Press the button labeled "PUSH" located at the bottom back of the phone. This will release the battery.
    • Lift and remove the battery.
  3. Motorola C139 SIM Card Replacement, SIM Card: passo 3, immagine 1 di 3 Motorola C139 SIM Card Replacement, SIM Card: passo 3, immagine 2 di 3 Motorola C139 SIM Card Replacement, SIM Card: passo 3, immagine 3 di 3
    • Do not bend or scratch the SIM card. In addition, keep it away from static electricity, dust, and water.
    • Gently slide the SIM card out and lift to remove it from the phone.
Conclusione
Clemson, Team 2-2, Benson Spring 2012 Membro di Clemson, Team 2-2, Benson Spring 2012
CLEM-BENSON-S12S2G2
3 Membri
15 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,038
