Salta al contenuto principale
Motorola Buzz ic502 Screen and Speaker Replacement
Cosa ti serve
  1. Motorola Buzz ic502 Screen and Speaker Replacement, Battery: passo 1, immagine 1 di 3 Motorola Buzz ic502 Screen and Speaker Replacement, Battery: passo 1, immagine 2 di 3 Motorola Buzz ic502 Screen and Speaker Replacement, Battery: passo 1, immagine 3 di 3
    • First flip the phone over.
    • Then find the back release circled in red.
  2. Motorola Buzz ic502 Screen and Speaker Replacement: passo 2, immagine 1 di 2 Motorola Buzz ic502 Screen and Speaker Replacement: passo 2, immagine 2 di 2
    • Carefully remove the back using the release.
    • Lift from the bottom!
  3. Motorola Buzz ic502 Screen and Speaker Replacement: passo 3, immagine 1 di 3 Motorola Buzz ic502 Screen and Speaker Replacement: passo 3, immagine 2 di 3 Motorola Buzz ic502 Screen and Speaker Replacement: passo 3, immagine 3 di 3
    • Lift the battery from the right side.
    • After the battery has lifted about a 45 degree angle remove from phone.
  4. Motorola Buzz ic502 Screen and Speaker Replacement, Screen Assembly: passo 4, immagine 1 di 3 Motorola Buzz ic502 Screen and Speaker Replacement, Screen Assembly: passo 4, immagine 2 di 3 Motorola Buzz ic502 Screen and Speaker Replacement, Screen Assembly: passo 4, immagine 3 di 3
    • Remove all six screws
    • The two top screws here
    • The two middle screws here.
    • And the two bottom screws here, they are covered by plastic pieces that first must be removed with the nylon Spudger.
  5. Motorola Buzz ic502 Screen and Speaker Replacement: passo 5, immagine 1 di 3 Motorola Buzz ic502 Screen and Speaker Replacement: passo 5, immagine 2 di 3 Motorola Buzz ic502 Screen and Speaker Replacement: passo 5, immagine 3 di 3
    • then carefully lift the front off the phone.
    • Marked wire will have to be solderd when re-connecting new screen
    • Speakers are connected to the screen here.
Conclusione
To reassemble your device, follow these instructions in reverse order, soldering wire onto new screen.
Austin Quinn
Membro da: 10/20/16
401 Reputazione
4 Guide realizzate
UMass Dartmouth, Team 6-6, Martin Fall 2016 Membro di UMass Dartmouth, Team 6-6, Martin Fall 2016
UMASSD-MARTIN-F16S6G6
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 103
