Salta al contenuto principale
Motorola Atrix HD Rear Chassis Disassembly
Cosa ti serve
  1. Motorola Atrix HD Rear Chassis Disassembly, Rear Chassis: passo 1, immagine 1 di 3 Motorola Atrix HD Rear Chassis Disassembly, Rear Chassis: passo 1, immagine 2 di 3 Motorola Atrix HD Rear Chassis Disassembly, Rear Chassis: passo 1, immagine 3 di 3
    • Begin by removing the back cover using the plastic opening tool. There are adhesive strips attached to the back cover, so take care when prying case to prevent cracking
    • The adhesive strips may stay on the back cover or the battery.
  2. Motorola Atrix HD Rear Chassis Disassembly: passo 2, immagine 1 di 2 Motorola Atrix HD Rear Chassis Disassembly: passo 2, immagine 2 di 2
    • The back case portion may be removed after the battery has been removed.
    • Use the T5 Torx screwdriver to remove the 10 coarse-thread 5mm screws
  3. Motorola Atrix HD Rear Chassis Disassembly: passo 3, immagine 1 di 3 Motorola Atrix HD Rear Chassis Disassembly: passo 3, immagine 2 di 3 Motorola Atrix HD Rear Chassis Disassembly: passo 3, immagine 3 di 3
    • Now with the screws removed, use the plastic opening tool to lift the edges of the front assembly.
    • Continue to use the plastic opening tool around the edges of the device to remove the front assembly.
    • The speaker is located in the upper corner of the case. It it attached with adhesive and can be removed by gently prying with the plastic opening tool
Conclusione
Altre 2 persone hanno completato questa guida.
UMass Dartmouth, Team 1-8, Miles Fall 2015 Membro di UMass Dartmouth, Team 1-8, Miles Fall 2015
UMASSD-MILES-F15S1G8
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 238
