Introduzione
The motherboard is the heart of your phone. In certain circumstances, damage to the motherboard will cause intermittent problems, or even prevent the phone from turning on at all. If your motherboard has been damaged, it is important to consider why. If the phone has been damaged due to water intrusion, more components may have been damaged.
Anytime you are working near a circuit board, static electricity is a concern. If possible, be sure to discharge any static electricity that may have built up on you or your tools before diving into the motherboard. If possible, conduct your work on a static-free surface, such as plastic, or even paper.
Cosa ti serve
Begin taking apart the device by prying apart the back cover from the assembly using the plastic opening tool.
Continue working around the edge of the phone using the plastic opening tool.
When all the edges have been lifted apart, use your hands or plastic opening tool to peel the back plate from the battery. There are small adhesive strips between the back cover and the battery, so take care not to crack the back cover while prying open.
Begin by removing the back cover using the plastic opening tool. There are adhesive strips attached to the back cover, so take care when prying case to prevent cracking
The adhesive strips may stay on the back cover or the battery.
Now with the screws removed, use the plastic opening tool to lift the edges of the front assembly.
Continue to use the plastic opening tool around the edges of the device to remove the front assembly.
The speaker is located in the upper corner of the case. It it attached with adhesive and can be removed by gently prying with the plastic opening tool
Begin by removing the 10 Torx T5 motherboard baseplate screws
The back chassis can now be removed.
Remove the three Torx T5 screws that locks the front facing camera to the motherboard.
Use the plastic opening tool to lift the ribbon cable from the motherboard.
Now the motherboard is ready to be replaced and reassembled in reverse order.
Altre 5 persone hanno completato questa guida.
