Salta al contenuto principale
Motorola Adventure V750 Front Glass Replacement
Cosa ti serve
    • Remove the back cover and battery of the Motorola Adventure V750.
    • Using a screwdriver, remove the four screws that are visible.
    • After removing the battery chamber, unclip one of the ribbons that connect the screen to the main body of the phone. This divides the phone in half.
    • Remove the two screws located at the bottom of the main display.
    • Remove the display screen by sliding a sharp object or fingernail along the edge of the housing.
    • Release the display up to the point where you see two metal parts (left and right of the Motorola text). The top part of the display is held on with double-sided tape.
    • Gently unstick the tape and remove the display. Be careful not to bend this part.
    • Carefully install the new glass.
Conclusione
Altre 2 persone hanno completato questa guida.
Kyle
Membro da: 10/01/12
605 Reputazione
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 700
