Introduzione
Use this guide to remove the earpiece speaker in the Motorola Moto C Plus.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Cosa ti serve
Insert a thumbnail, or spudger, into the notch on the bottom right to start separating the phone unit from the back cover.
Move to the bottom left corner and pry the phone unit out of the back cover until you can get a good grip.
Use a spudger or fingernail to lift the battery starting at the notch on the bottom left.
Lever the battery out of its recess and remove it.
Remove the six 3.1 mm Phillips #00 screws securing the daughterboard cover.
Remove the two 3.2 mm Phillips #00 screws securing the motherboard.
Use an iOpener and apply it to the top edge of the display to loosen the adhesive beneath the earpiece speaker.
Altre 2 persone hanno completato questa guida.
