Introduzione
This task requires the removal of small screws. Be sure you have a secure place to keep the screws such as a magnetic mat.
Cosa ti serve
Insert the plastic opening tool into the middle of the bottom edge of the device. The tool should be inserted within the seam between the back and front covers.
Slide the opening tool to the right and slowly continue to separate the back cover from the device.
Remove the two ZIF connectors attached to the motherboard by flipping up the black tabs before pulling the ribbon cable away.
