Salta al contenuto principale
Motherboard Cover Removal
Solo Prerequisita
Questa guida è destinata a essere usata solo come prerequisito per altre guide. Da sola è incompleta.
Cosa ti serve
  1. Motherboard Cover Removal, Rear Glass: passo 1, immagine 1 di 1
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to a long edge of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
  2. Motherboard Cover Removal: passo 2, immagine 1 di 3 Motherboard Cover Removal: passo 2, immagine 2 di 3 Motherboard Cover Removal: passo 2, immagine 3 di 3
    • If the phone's rear glass is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Press a suction cup onto the back cover.
    • Lift the back cover's right edge with your suction cup, opening a slight gap between the back cover and the frame.
    • Insert the tip of an opening pick in the gap you created and slide it to the bottom right corner.
  3. Motherboard Cover Removal: passo 3, immagine 1 di 2 Motherboard Cover Removal: passo 3, immagine 2 di 2
    • Apply more heat if the adhesive becomes hard to cut. During the removal process, the back cover is under tension all the time and is likely to break if the adhesive isn't softened enough.
    • Insert a second opening pick at the bottom right corner of the rear glass.
    • Slide the opening pick along the bottom edge of the rear glass to cut the adhesive and leave it in the bottom left corner.
  4. Motherboard Cover Removal: passo 4, immagine 1 di 3 Motherboard Cover Removal: passo 4, immagine 2 di 3 Motherboard Cover Removal: passo 4, immagine 3 di 3
    • Insert a third opening pick at the bottom left corner of the rear glass.
    • Slide the opening pick along the left edge of the rear glass to cut the adhesive.
    • Leave the opening pick at the top left corner of the rear glass.
  5. Motherboard Cover Removal: passo 5, immagine 1 di 2 Motherboard Cover Removal: passo 5, immagine 2 di 2
    • Insert a fourth opening pick at the top left corner of the rear glass.
    • Slide the opening along the top edge of the rear glass and cut the remaining adhesive with it.
  6. Motherboard Cover Removal: passo 6, immagine 1 di 2 Motherboard Cover Removal: passo 6, immagine 2 di 2
    • Carefully lift the rear glass of the Huawei Honor 10 and remove it.
  7. Motherboard Cover Removal, Battery disconnect: passo 7, immagine 1 di 3 Motherboard Cover Removal, Battery disconnect: passo 7, immagine 2 di 3 Motherboard Cover Removal, Battery disconnect: passo 7, immagine 3 di 3
    • Use a pair of tweezer to carefully peel the black foil off the loudspeaker and daughterboard cover.
    • Remove the foil completely.
  8. Motherboard Cover Removal: passo 8, immagine 1 di 1
    • Remove the three Phillips #00 screws (2.9 mm length) that secure the metal bracket on top of the battery, interconnect, and display flex cable.
  9. Motherboard Cover Removal: passo 9, immagine 1 di 2 Motherboard Cover Removal: passo 9, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Use a pair of tweezers to remove the metal shield that covers the connectors of the interconnect cable, the battery and the display flex cable.
  10. Motherboard Cover Removal: passo 10, immagine 1 di 2 Motherboard Cover Removal: passo 10, immagine 2 di 2
    • Use a spudger to pry up and disconnect the battery flex cable.
  11. Motherboard Cover Removal, Motherboard Cover: passo 11, immagine 1 di 1
    • Remove the six Phillips screws securing the motherboard cover:
    • Four 3.4 mm long screws
    • Two 2.9 mm long screws
  12. Motherboard Cover Removal: passo 12, immagine 1 di 3 Motherboard Cover Removal: passo 12, immagine 2 di 3 Motherboard Cover Removal: passo 12, immagine 3 di 3
    • Slide an opening pick under the motherboard cover next to the cameras and carefully pry it up by twisting the opening pick sideways.
    • Repeat the previous process on the opposite side of the motherboard cover until the cover pops out.
    • Remove the motherboard cover.
Conclusione
You’ll need replacement adhesive to reattach the battery and back cover when reassembling the device.
iFixit Membro di iFixit
Staff
118 Membri
19.527 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 23
