Salta al contenuto principale
Morrison's Morphy Richards Soup Maker error codes
  1. Morrison's Morphy Richards Soup Maker error codes, Morrison's Morphy Richards Soup Maker error codes: passo 1, immagine 1 di 3 Morrison's Morphy Richards Soup Maker error codes, Morrison's Morphy Richards Soup Maker error codes: passo 1, immagine 2 di 3 Morrison's Morphy Richards Soup Maker error codes, Morrison's Morphy Richards Soup Maker error codes: passo 1, immagine 3 di 3
    • Manufactured by Morphy Richards and sold by Morrisons.... these soup makers are renowned to fail... this is normal due to being overfilled or the soup product not being prepared enough ( veg etc MUST be no larger than 10mm×10mm×10mm ) or it WILL jam the blades.. and if over filled will also force premature failure...
    • the unit will show an error code of E1 E2 or E3 on digital panel E1 blades jammed E2 not enough liquid to boil and E3 to much wedged into pot thus causing the sensor in the lid to get covered and short out... all 3 errors are operator error ...
    • switch off the unit for 10 sec allowing it to reset either add or remove soup items as required replace lid return power and try again.... GOOD LUCK enjoy your healthy stress free soup....
Conclusione
Altre 5 persone hanno completato questa guida.
damian s
Membro da: 10/21/14
169 Reputazione
1 Guida realizzata
46 Commenti
Came to this site cos I was getting E3 error took lid off give it a good clean making sure all silver metal bits was throughly clean, above made sense as I used two bags of casserole mix from tescos instead of one. Defo wont be doing that again!!
treefella72 - Replica
Glad to be able to help make sense of the error..
I was getting infuriated with mine when it kept turning off..
They are a great utensil when working..
damian s -
Smooth mode, went right through programme bit failed to heat contents. Second time showed E1 error code, removed lid and cleaned blade, followed instructions, unit still failed to heat soup, has been used for only 6 months so dissappointed.
tinkerfk - Replica
If only 6 months old I would return it to the store for a replacement as it could be the sensor or the heater element failed.. when they work they are a good unit but the amount of these that are failing is terrible.. Good luck in sorting yours out…
damian s -
Hello YES I was getting a lot of E1 Error messages.. Had to put out half the Soup mix SQUASH into small pieces then refill A bit of a pait as I would really like to have the Soup Chunky
When it works It is Good soup maker
Not had any E2 or E3 Errors
Rgds
GD
bigg7757 -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 12
Ultimi 7 Giorni: 58
Ultimi 30 Giorni: 181
Tutti i Tempi: 49,139
