Salta al contenuto principale
Montgomery Ward GEN-39500 Internal Power Supply Replacement
Cosa ti serve
  1. Montgomery Ward GEN-39500 Internal Power Supply Replacement, Back Cover: passo 1, immagine 1 di 1
    • Remove the nine 35 mm Phillips screws securing the back cover of the case.
  2. Montgomery Ward GEN-39500 Internal Power Supply Replacement: passo 2, immagine 1 di 1
    • Carefully remove the back cover.
    • Soldered wires connect electronics on the back cover to the internal electronics. Be careful not to break any connections.
  3. Montgomery Ward GEN-39500 Internal Power Supply Replacement: passo 3, immagine 1 di 2 Montgomery Ward GEN-39500 Internal Power Supply Replacement: passo 3, immagine 2 di 2
    • Unplug the black and yellow wires connecting the power supply unit to the rest of the electronics:
    • This is not necessarily required. This step is to allow the back cover more movement as you work on the inside of the unit.
  4. Montgomery Ward GEN-39500 Internal Power Supply Replacement, Internal Power Supply: passo 4, immagine 1 di 1
    • Unscrew the six 10 mm Phillips screws holding the mounting plate in place.
  5. Montgomery Ward GEN-39500 Internal Power Supply Replacement: passo 5, immagine 1 di 3 Montgomery Ward GEN-39500 Internal Power Supply Replacement: passo 5, immagine 2 di 3 Montgomery Ward GEN-39500 Internal Power Supply Replacement: passo 5, immagine 3 di 3
    • Unsolder the wires connecting the power supply unit to the battery container.
  6. Montgomery Ward GEN-39500 Internal Power Supply Replacement: passo 6, immagine 1 di 1
    • Remove the power supply unit.
Conclusione
Cal Poly, Team 12-5, Lancaster Spring 2015 Membro di Cal Poly, Team 12-5, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G5
4 Membri
13 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 5
Tutti i Tempi: 108
