Salta al contenuto principale
Montgomery Ward GEN-39500 Back Cover Replacement
Cosa ti serve
  1. Montgomery Ward GEN-39500 Back Cover Replacement, Back Cover: passo 1, immagine 1 di 1
    • Remove the nine 35 mm Phillips screws securing the back cover of the case.
  2. Montgomery Ward GEN-39500 Back Cover Replacement: passo 2, immagine 1 di 1
    • Carefully remove the back cover.
    • Soldered wires connect electronics on the back cover to the internal electronics. Be careful not to break any connections.
  3. Montgomery Ward GEN-39500 Back Cover Replacement: passo 3, immagine 1 di 2 Montgomery Ward GEN-39500 Back Cover Replacement: passo 3, immagine 2 di 2
    • Unplug the black and yellow wires connecting the power supply unit to the rest of the electronics:
    • This is not necessarily required. This step is to allow the back cover more movement as you work on the inside of the unit.
Conclusione
Cal Poly, Team 12-5, Lancaster Spring 2015 Membro di Cal Poly, Team 12-5, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G5
4 Membri
13 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 89
