Salta al contenuto principale
Monteren en demonteren van een tablet
Cosa ti serve
  1. Monteren en demonteren van een tablet, Monteren en demonteren van een tablet: passo 1, immagine 1 di 1
    • The hull seen from the front.
  2. Monteren en demonteren van een tablet: passo 2, immagine 1 di 1
    • The case seen from the back, with the jacks where to connect your handsets
  3. Monteren en demonteren van een tablet: passo 3, immagine 1 di 1
    • Enough to redo a shell in case of problems, but without the feet.
    • The T14 snake-eyes tip to disassemble the facade.
    • Collars to block the jacks of your handsets under the shell.
    • Replacement snake eyes M6 screws, M6 inserts to remake a shell
  4. Monteren en demonteren van een tablet: passo 4, immagine 1 di 1
    • Use the tip to disassemble the screws.
    • DO IT MANUALLY!!!
    • Not to the screwdriver, because it will rip. And the tip will damage the facade.
  5. Monteren en demonteren van een tablet: passo 5, immagine 1 di 1
    • To block the jacks of the handsets: make a knot on the collar.
    • Thus, users will not be able to disconnect the handsets
  6. Monteren en demonteren van een tablet: passo 6, immagine 1 di 1
    • If you want to redo a shell:
    • You have to cut the inserts, and pierce the bottom to pass the usb plug and the jack that connects to the tablet.
    • Take the model delivered as an example
  7. Monteren en demonteren van een tablet: passo 7, immagine 1 di 1
    • To change the content of the micro SD card:
    • You must disassemble the facade, remove the tablet from the shell and open the "SD card" hatch
    • Create a file named: sexbreizh.avi
    • AVI container, mp3 audio codec, xvid video codec
    • Audio bitrate: 44100
    • Video rate: 8000
Conclusione
Om het apparaat weer in elkaar te zetten, volg je deze instructies in omgekeerde volgorde.
Altre 5 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
fr en
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 40
Tutti i Tempi: 778
