Introduzione
This guide will help you disconnect and replace the rear panel connectors of the speaker.
Cosa ti serve
Use a spudger or your fingers to pry off and remove the rubber pad on the bottom of the speaker.
After removing grille, you will see the speakers.
Remove the eight 10mm screws that surround the speakers. There will be four around each speaker.
Identify the eight screws around the border of the front panel.
Using the TR 10 driver, remove the two 8mm screws.
Using the TR 10 driver, remove the six 12mm screws.
Use a TR 10 driver to remove the two 10mm screws securing the connector housing.
Remove the housing from the rear panel.
Altre 2 persone hanno completato questa guida.
