Salta al contenuto principale
Monster SoundStage S1 Mini Speaker Replacement
Cosa ti serve
  1. Monster SoundStage S1 Mini Speaker Replacement, Speaker: passo 1, immagine 1 di 2 Monster SoundStage S1 Mini Speaker Replacement, Speaker: passo 1, immagine 2 di 2
    • Remove the speaker wires from the motherboard by pinching the plastic tab at the end of the cable and pulling towards you.
  2. Monster SoundStage S1 Mini Speaker Replacement: passo 2, immagine 1 di 2 Monster SoundStage S1 Mini Speaker Replacement: passo 2, immagine 2 di 2
    • Unscrew 1.2 cm Torx security screw, holding the silver circle connector, to disconnect the wire from the speakerboard to the motherboard
  3. Monster SoundStage S1 Mini Speaker Replacement: passo 3, immagine 1 di 1
    • Remove the black putty from the speaker wires at both ends of the speaker board.
  4. Monster SoundStage S1 Mini Speaker Replacement: passo 4, immagine 1 di 3 Monster SoundStage S1 Mini Speaker Replacement: passo 4, immagine 2 di 3 Monster SoundStage S1 Mini Speaker Replacement: passo 4, immagine 3 di 3
    • Solder the black plastic encasing the red and black wires.
  5. Monster SoundStage S1 Mini Speaker Replacement: passo 5, immagine 1 di 2 Monster SoundStage S1 Mini Speaker Replacement: passo 5, immagine 2 di 2
    • Remove both the black and red wires with pliers
    • Pliers may stick to speaker because it is magnetic.
  6. Monster SoundStage S1 Mini Speaker Replacement: passo 6, immagine 1 di 2 Monster SoundStage S1 Mini Speaker Replacement: passo 6, immagine 2 di 2
    • Tuck wires through the hole where the speaker is located, then gently push the speaker out.
    • The 1.2 cm Torx security screws that stayed in place near the speaker will now fall out.
    • To remove the other speaker repeat steps 3-6
Conclusione
CSU Fullerton, Team 2-6, Bruce Fall 2016 Membro di CSU Fullerton, Team 2-6, Bruce Fall 2016
CSUF-BRUCE-F16S2G6
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 512
