Salta al contenuto principale
Moen Posi-Temp Cartridge Part #1112b Replacement
Cosa ti serve
  1. Moen Posi-Temp Cartridge Part #1112b Replacement, Moen Posi-Temp Cartridge Part #1112b: passo 1, immagine 1 di 1
    • Turn the water shutoff valve counter-clockwise to the "off" position.
  2. Moen Posi-Temp Cartridge Part #1112b Replacement: passo 2, immagine 1 di 1
    • Open both the hot and cold taps of a nearby faucet or shower until the water no longer flows.
  3. Moen Posi-Temp Cartridge Part #1112b Replacement: passo 3, immagine 1 di 2 Moen Posi-Temp Cartridge Part #1112b Replacement: passo 3, immagine 2 di 2
    • Turn the handle of the shower valve 180 degrees until it is in the "up" or "on" position.
  4. Moen Posi-Temp Cartridge Part #1112b Replacement: passo 4, immagine 1 di 2 Moen Posi-Temp Cartridge Part #1112b Replacement: passo 4, immagine 2 di 2
    • Unscrew the handle screw with an Allen wrench.
    • Remove the handle.
  5. Moen Posi-Temp Cartridge Part #1112b Replacement: passo 5, immagine 1 di 2 Moen Posi-Temp Cartridge Part #1112b Replacement: passo 5, immagine 2 di 2
    • Remove the handle adaptor screw with a Phillips screwdriver.
    • Remove the handle adaptor simply by pulling it out.
  6. Moen Posi-Temp Cartridge Part #1112b Replacement: passo 6, immagine 1 di 1
    • Pull out the white key/adjustable limit stop.
  7. Moen Posi-Temp Cartridge Part #1112b Replacement: passo 7, immagine 1 di 3 Moen Posi-Temp Cartridge Part #1112b Replacement: passo 7, immagine 2 di 3 Moen Posi-Temp Cartridge Part #1112b Replacement: passo 7, immagine 3 di 3
    • Gently pull out the stop tube.
  8. Moen Posi-Temp Cartridge Part #1112b Replacement: passo 8, immagine 1 di 3 Moen Posi-Temp Cartridge Part #1112b Replacement: passo 8, immagine 2 di 3 Moen Posi-Temp Cartridge Part #1112b Replacement: passo 8, immagine 3 di 3
    • Using the Phillips head screwdriver, remove the two screws located at the top right corner and bottom left corner.
    • Remove the metal plate.
  9. Moen Posi-Temp Cartridge Part #1112b Replacement: passo 9, immagine 1 di 3 Moen Posi-Temp Cartridge Part #1112b Replacement: passo 9, immagine 2 di 3 Moen Posi-Temp Cartridge Part #1112b Replacement: passo 9, immagine 3 di 3
    • Slide the tip of needle-nose pliers under the notch of the retaining clip and pull the clip upwards.
  10. Moen Posi-Temp Cartridge Part #1112b Replacement: passo 10, immagine 1 di 3 Moen Posi-Temp Cartridge Part #1112b Replacement: passo 10, immagine 2 di 3 Moen Posi-Temp Cartridge Part #1112b Replacement: passo 10, immagine 3 di 3
    • Clamp firmly onto the brass tube with a pair of vice grips and gently but firmly pull out the cartridge.
  11. Moen Posi-Temp Cartridge Part #1112b Replacement: passo 11, immagine 1 di 2 Moen Posi-Temp Cartridge Part #1112b Replacement: passo 11, immagine 2 di 2
    • Insert the new Moen Posi-Temp cartridge.
  12. Moen Posi-Temp Cartridge Part #1112b Replacement: passo 12, immagine 1 di 1
    • Insert the new cartridge into the valve assembly.
    • Ensure that the H/C symbols are facing up.
    • Ensure that the notch on the brass tube is also facing up.
Conclusione
John Mendoza
Membro da: 09/17/20
205 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 22
Tutti i Tempi: 1,409
