Salta al contenuto principale
Modal Rechargeable Wine Opener Power Button Replacement
Cosa ti serve
  1. Modal Rechargeable Wine Opener Power Button Replacement, Modal Rechargeable Wine Opener power button: passo 1, immagine 1 di 1
    • Carefully place the spudger under the black cylindrical ring and pry it off the top.
  2. Modal Rechargeable Wine Opener Power Button Replacement: passo 2, immagine 1 di 1
    • Remove the spring
    • Remove the spring guide as well to obtain clear access to the screws
  3. Modal Rechargeable Wine Opener Power Button Replacement: passo 3, immagine 1 di 3 Modal Rechargeable Wine Opener Power Button Replacement: passo 3, immagine 2 di 3 Modal Rechargeable Wine Opener Power Button Replacement: passo 3, immagine 3 di 3
    • Remove all four 4mm screws with a J1 Screwdriver
    • Remove the clear cylindrical cap
  4. Modal Rechargeable Wine Opener Power Button Replacement: passo 4, immagine 1 di 3 Modal Rechargeable Wine Opener Power Button Replacement: passo 4, immagine 2 di 3 Modal Rechargeable Wine Opener Power Button Replacement: passo 4, immagine 3 di 3
    • Apply pressure to both of the springs on the surface near the corkscrew, releasing the button port.
  5. Modal Rechargeable Wine Opener Power Button Replacement: passo 5, immagine 1 di 3 Modal Rechargeable Wine Opener Power Button Replacement: passo 5, immagine 2 di 3 Modal Rechargeable Wine Opener Power Button Replacement: passo 5, immagine 3 di 3
    • Remove the malfunctioning buttons from the plastic frame.
Conclusione
Lauren Spicher
Membro da: 02/15/17
101 Reputazione
1 Guida realizzata
USF Tampa, Team 15-4, Remmell Spring 2017 Membro di USF Tampa, Team 15-4, Remmell Spring 2017
USFT-REMMELL-S17S15G4
4 Membri
2 Guide realizzate
4Commenti sulla guida
where do you by the replacement switch?
Stan Okumura - Replica
are there any posts for fixing the usb charging port?
Cristian Sanabria - Replica
If the lights work, the buttons are not the problem. I can get the cork screw to turn manually, but it will not continue run beyond a few tries. Must be the motor.
tom.o@mac.com - Replica
Could be also the battery. I will try to change the battery.
Daniel Siegenthaler -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 25
Tutti i Tempi: 9,220
