Salta al contenuto principale
Modal MD-WORCSS6 Battery Replacement
Cosa ti serve
  1. Modal MD-WORCSS6 Battery Replacement, Modal MD-WORCSS6 Teardown Guide: passo 1, immagine 1 di 2 Modal MD-WORCSS6 Battery Replacement, Modal MD-WORCSS6 Teardown Guide: passo 1, immagine 2 di 2
    • Put on Electrostatic Discharge (ESD) bracelet. Hold the device with the transparent plastic casing on the top.
    • Using the jimmy tool, carefully pry off the black plastic ring.
    • Remove the spring assembly from inside the transparent plastic tube.
  2. Modal MD-WORCSS6 Battery Replacement: passo 2, immagine 1 di 2 Modal MD-WORCSS6 Battery Replacement: passo 2, immagine 2 di 2
    • Using a Phillips #1 screwdriver, unscrew each of the four 12.7 mm screws inside and at the bottom of the plastic tube.
    • Take the plastic tube off of the metal casing.
  3. Modal MD-WORCSS6 Battery Replacement: passo 3, immagine 1 di 2 Modal MD-WORCSS6 Battery Replacement: passo 3, immagine 2 di 2
    • Place the jimmy tool blade between the button assembly and the metal casing. Gently pry off the button assembly; it should pop out.
    • With the button assembly removed, slide off the metal casing.
  4. Modal MD-WORCSS6 Battery Replacement: passo 4, immagine 1 di 3 Modal MD-WORCSS6 Battery Replacement: passo 4, immagine 2 di 3 Modal MD-WORCSS6 Battery Replacement: passo 4, immagine 3 di 3
    • Unscrew the two 6.4 mm screws in the black plastic body using the Phillips #1 screwdriver.
    • Separate the two halves of the plastic body. Keep the half containing the motor facing up.
  5. Modal MD-WORCSS6 Battery Replacement: passo 5, immagine 1 di 3 Modal MD-WORCSS6 Battery Replacement: passo 5, immagine 2 di 3 Modal MD-WORCSS6 Battery Replacement: passo 5, immagine 3 di 3
    • Carefully peel the tape off far enough to remove the 3 batteries.
  6. Modal MD-WORCSS6 Battery Replacement, Battery: passo 6, immagine 1 di 1
    • Replace the batteries by pulling them out of their holder and putting new ones in the same places.
Conclusione
Altre 3 persone hanno completato questa guida.
Un commento
Where do you get the replacement batteries?
Gerry David - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,107
