Salta al contenuto principale
Modal MD-SPBT01 Speaker Wiring Replacement
Cosa ti serve
  1. Modal MD-SPBT01 Speaker Wiring Replacement, Speaker Wiring: passo 1, immagine 1 di 2 Modal MD-SPBT01 Speaker Wiring Replacement, Speaker Wiring: passo 1, immagine 2 di 2
    • Use the plastic opening tool to pull the metal cover off the top of the speaker.
  2. Modal MD-SPBT01 Speaker Wiring Replacement: passo 2, immagine 1 di 1
    • Remove the four screws that are inside the holes on the top of the speaker.
    • Use a Phillips 00 screwdriver to remove the 10mm screws.
  3. Modal MD-SPBT01 Speaker Wiring Replacement: passo 3, immagine 1 di 1
    • Pull the top piece of the speaker off to allow access to the interior.
  4. Modal MD-SPBT01 Speaker Wiring Replacement: passo 4, immagine 1 di 1
    • Locate the speaker wire connection and remove the wiring.
    • Locate the LED lighting wire and remove that as well.
  5. Modal MD-SPBT01 Speaker Wiring Replacement: passo 5, immagine 1 di 1
    • Once you disconnect the wires, you can remove the speaker.
  6. Modal MD-SPBT01 Speaker Wiring Replacement: passo 6, immagine 1 di 2 Modal MD-SPBT01 Speaker Wiring Replacement: passo 6, immagine 2 di 2
    • Remove the positive and negative connections for the wiring to fully disconnect the wire.
    • Now that you have removed the defective wiring, you can install a new one.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 497
