Salta al contenuto principale
Modal MD-SPBT01 Metal Speaker Covering Replacement
Cosa ti serve
  1. Modal MD-SPBT01 Metal Speaker Covering Replacement, Metal Speaker Covering: passo 1, immagine 1 di 2 Modal MD-SPBT01 Metal Speaker Covering Replacement, Metal Speaker Covering: passo 1, immagine 2 di 2
    • Remove the damaged metal speaker covering using the plastic opening tool.
    • The covering may be damaged that it is already out of its original place. If this is the condition, you may skip this step.
  2. Modal MD-SPBT01 Metal Speaker Covering Replacement: passo 2, immagine 1 di 1
    • Line up the replacement metal covering with the interior square ridge of the speaker.
  3. Modal MD-SPBT01 Metal Speaker Covering Replacement: passo 3, immagine 1 di 1
    • Firmly press the metal cover into the speaker until it is snug.
    • Super glue may be used to keep the cover in its place, although it is not necessary.
Linea Traguardo
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 440
