Salta al contenuto principale
Modal MD-SPBT01 LED Light Wiring Replacement
Cosa ti serve
  1. Modal MD-SPBT01 LED Light Wiring Replacement, LED Light Wiring: passo 1, immagine 1 di 2 Modal MD-SPBT01 LED Light Wiring Replacement, LED Light Wiring: passo 1, immagine 2 di 2
    • Use your plastic opening tool to pry the metal speaker cover off.
  2. Modal MD-SPBT01 LED Light Wiring Replacement: passo 2, immagine 1 di 1
    • You can now use the Phillips #00 screwdriver to remove the four screws.
  3. Modal MD-SPBT01 LED Light Wiring Replacement: passo 3, immagine 1 di 1
    • With the screws removed, you can now remove the top piece of the speaker to gain access to the interior.
  4. Modal MD-SPBT01 LED Light Wiring Replacement: passo 4, immagine 1 di 1
    • Locate the LED wire connection and remove it from the mother board.
    • To make replacing the LED wiring easier, remove the speaker wire to fully disconnect the speaker from the mother board.
  5. Modal MD-SPBT01 LED Light Wiring Replacement: passo 5, immagine 1 di 1
    • Now you can remove the wiring from the speaker side of the device.
    • It might take a bit of work to remove the wires because they are glued down on this side.
  6. Modal MD-SPBT01 LED Light Wiring Replacement: passo 6, immagine 1 di 1
    • Now with the LED wiring removed, a new wire can be installed.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 730
