Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
Accessing the lamp in this television is straightforward and requires minimal disassembly.
  1. Before disassembling your television, be sure it is powered off and unplugged.
    • Before disassembling your television, be sure it is powered off and unplugged.
    • Remove the single 18 mm Phillips #1 screw on the lamp access panel.
  2. Pull the lamp access panel off of the back panel of the television by pulling straight back on the left side of the panel near the screw then pulling to the left.
    • Pull the lamp access panel off of the back panel of the television by pulling straight back on the left side of the panel near the screw then pulling to the left.
  3. Loosen the two Phillips #2 screws securing the lamp housing to the television until the screws will swivel vertically.
    • Loosen the two Phillips #2 screws securing the lamp housing to the television until the screws will swivel vertically.
    • These two screws are permanently attached to the lamp housing and cannot be removed completely.
  4. Using the handle, pull the lamp housing straight back out of the television.
    • Using the handle, pull the lamp housing straight back out of the television.
    • Do not touch the glass of the lamp with your bare hands. The oil from your fingers can distort the TV image and lead to other issues.
Conclusione
Herman Chai
Membro da: 02/10/2012
196 Reputazione
3 Guide realizzate
Cal Poly, Team 18-39, Regan Fall 2012 Membro di Cal Poly, Team 18-39, Regan Fall 2012
CPSU-REGAN-F12S18G39
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,989
