Introduzione
This guide will detail the installation of a new DLP chip into the light engine of the TV. Replacing the chip will often remove stationary white and black spots that appear over time.
Cosa ti serve
Remove the following 8 Phillips #1 screws:
One 22 mm Phillips #1 in the bottom right corner of the back panel.
One 18 mm Phillips #1 in the top middle of the back panel.
Six 18 mm Phillips #1 in the rest of the back panel.
Disconnect the light engine power cable by holding its white tab and pulling straight back.
Disconnect the four connections above the black data connection by gently pulling the plugs out of the sockets (some of the connections have a tab that must be pressed when pulling to disconnect).
Use pliers to remove the two securing bolts from above and below the data port by rotating counterclockwise.
Remove the seven 8 mm Phillips #0 screws holding the plate to the light engine board.
Gently hold each side of the metal frame and pull it straight back to reveal the board and heat sinks underneath.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Carefully pull the board to expose the two cables that connect to the back of the board.
Use pliers and tweezers to disconnect the ribbon cable by pulling it straight out of its socket and the data connector by holding its tab and pulling it straight back from the board.
Replacing the ribbon cable is the hardest step when you reassemble. You'll need to align the board with the bolt holes, and using fingers or tweezers line the ribbon with the slot (which you can't see) and push fairly hard to mate the connector. This cable goes to the color wheel. Be careful not to flip it upside down.
Tip: Plugging the holes with some painter's tape may make it harder for the wires to slip into the light engine once detached.
Altre 5 persone hanno completato questa guida.
7 Commenti
Great guide... I found another similar guide on FixYourDLP website by googling "Replacing the 4719-001997 DLP Chip" and used a merger of both to fix my TV. The big difference was the number of steps and the detail to which both guides follow.
Here is the link:
Thanks to this guide my Mitzubishi TV is as good as new. Bought a DLP chip on line for $130 and used this guide to replace it and no more white dots!
The pictures and steps in this guide perfectly depicted my TV so completed the whole chip replacement in about 1/2 hour. Thanks!
What can you do if the ribbon cable in step 10 breaks? Is that entire cable replacable or the entire component? Is it very costly? Wish i had found this before I tried the replacement of the chip.
