Salta al contenuto principale
Mitsubishi T200 Screen Replacement
Cosa ti serve
  1. Mitsubishi T200 Screen Replacement, Screen: passo 1, immagine 1 di 2 Mitsubishi T200 Screen Replacement, Screen: passo 1, immagine 2 di 2
    • Begin disassembling the phone by removing the phone back cover and battery.
  2. Mitsubishi T200 Screen Replacement: passo 2, immagine 1 di 1
    • To remove the back plate, loosen and remove the four screws by using a #00 Philips head screwdriver.
  3. Mitsubishi T200 Screen Replacement: passo 3, immagine 1 di 1
    • Separate the front plastic component from the motherboard component.
  4. Mitsubishi T200 Screen Replacement: passo 4, immagine 1 di 1
    • Take the circuit board off the motherboard.
  5. Mitsubishi T200 Screen Replacement: passo 5, immagine 1 di 2 Mitsubishi T200 Screen Replacement: passo 5, immagine 2 di 2
    • Unclip the four clips to remove the screen (connected to the clear plastic) from the circuit board.
  6. Mitsubishi T200 Screen Replacement: passo 6, immagine 1 di 2 Mitsubishi T200 Screen Replacement: passo 6, immagine 2 di 2
    • Remove the attached ribbon from the circuit board by prying open the gray plastic clip at the top right of the circuit board.
  7. Mitsubishi T200 Screen Replacement: passo 7, immagine 1 di 2 Mitsubishi T200 Screen Replacement: passo 7, immagine 2 di 2
    • We can now insert the new screen and reassemble the device.
    • Place the ribbon of the new screen into the clip on the top right of the circuit board.
  8. Mitsubishi T200 Screen Replacement: passo 8, immagine 1 di 1
    • Clip the new screen onto the circuit board.
  9. Mitsubishi T200 Screen Replacement: passo 9, immagine 1 di 1
    • Replace circut board back on top of motherboard.
  10. Mitsubishi T200 Screen Replacement: passo 10, immagine 1 di 1
    • Take the entire internal assembly and join it with the front plastic housing.
    • Ensure that the tops of both pieces clip into place before joining the bottom ones.
  11. Mitsubishi T200 Screen Replacement: passo 11, immagine 1 di 1
    • Join the phone's face assembly to the back plastic housing. Make sure you carefully insert the front into the antenna's clip first.
    • Snap the whole unit together.
  12. Mitsubishi T200 Screen Replacement: passo 12, immagine 1 di 1
    • Firmly replace screws into the backing.
Linea Traguardo
Altre 2 persone hanno completato questa guida.
Ohio State, Team 1-5, Meza Spring 2014 Membro di Ohio State, Team 1-5, Meza Spring 2014
OSU-MEZA-S14S1G5
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 839
