Salta al contenuto principale
Mitsubishi Diamondpoint NXM76LCD Speaker Replacement
Cosa ti serve
  1. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Removing the stand.: passo 1, immagine 1 di 3 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Removing the stand.: passo 1, immagine 2 di 3 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Removing the stand.: passo 1, immagine 3 di 3
    • Lift the black cover off.
    • Remove all 4 Phillips #2 screws.
  2. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the 5 screws: passo 2, immagine 1 di 1
    • Remove the two 24mm Phillips #2 screws.
    • Remove the three 8mm Phillips #2 screws.
  3. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the back panel: passo 3, immagine 1 di 3 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the back panel: passo 3, immagine 2 di 3 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the back panel: passo 3, immagine 3 di 3
    • Lift the back and pry the back off.
    • The panel is held in with clips on the side. It needs a lot of force the take it off.
  4. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the four screws: passo 4, immagine 1 di 2 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the four screws: passo 4, immagine 2 di 2
    • Remove the four 5mm nut screws.
  5. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: passo 5, immagine 1 di 2 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: passo 5, immagine 2 di 2
    • Remove the seven Phillips #1 screws.
  6. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the front board: passo 6, immagine 1 di 2 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the front board: passo 6, immagine 2 di 2
    • Remove the three Phillips #2 screws.
    • Remove the two data/power cables.
    • Remove the two speaker cables.
  7. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: passo 7, immagine 1 di 2 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: passo 7, immagine 2 di 2
    • Remove the Phillips #2 screws from the speaker(s).
  8. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: passo 8, immagine 1 di 3 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: passo 8, immagine 2 di 3 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: passo 8, immagine 3 di 3
    • Pull the speaker off the slots.
Conclusione
Padraic Hoselton
Membro da: 08/22/17
4.270 Reputazione
12 Guide realizzate
Master Techs Membro di Master Techs
Community
327 Membri
1.697 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 124
