Salta al contenuto principale
Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement
Cosa ti serve
  1. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Removing the stand.: passo 1, immagine 1 di 3 Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Removing the stand.: passo 1, immagine 2 di 3 Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Removing the stand.: passo 1, immagine 3 di 3
    • Lift the black cover off.
    • Remove all 4 Phillips #2 screws.
  2. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the 5 screws: passo 2, immagine 1 di 1
    • Remove the two 24mm Phillips #2 screws.
    • Remove the three 8mm Phillips #2 screws.
  3. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the back panel: passo 3, immagine 1 di 3 Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the back panel: passo 3, immagine 2 di 3 Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the back panel: passo 3, immagine 3 di 3
    • Lift the back and pry the back off.
    • The panel is held in with clips on the side. It needs a lot of force the take it off.
  4. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the four screws: passo 4, immagine 1 di 2 Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the four screws: passo 4, immagine 2 di 2
    • Remove the four 5mm nut screws.
  5. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the 5 screws: passo 5, immagine 1 di 2 Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the 5 screws: passo 5, immagine 2 di 2
    • Remove the seven Phillips #1 screws.
  6. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the cables: passo 6, immagine 1 di 3 Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the cables: passo 6, immagine 2 di 3 Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the cables: passo 6, immagine 3 di 3
    • Remove all the cables.
  7. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the motherboard: passo 7, immagine 1 di 3 Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the motherboard: passo 7, immagine 2 di 3 Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the motherboard: passo 7, immagine 3 di 3
    • Remove the four screws.
    • Pull the motherboard up and off.
  8. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement: passo 8, immagine 1 di 1
    • Now you can replace it with a new one.
Conclusione
Padraic Hoselton
Membro da: 08/22/17
4.270 Reputazione
12 Guide realizzate
Master Techs Membro di Master Techs
Community
327 Membri
1.697 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 181
