Introduzione
If you want to replace your watch strap if it is damaged or for cosmetic purposes you can do so by following these steps.
Using your fingers, press down on the rubber circles to unbuckle the strap from itself.
Once you have removed two of the rubber circles from from a side you will be able to unbuckle the strap on that side.
