Salta al contenuto principale
Minolta X-370 Battery Replacement
Cosa ti serve
  1. Minolta X-370 Battery Replacement, Minolta X-370 Battery Replacement: passo 1, immagine 1 di 2 Minolta X-370 Battery Replacement, Minolta X-370 Battery Replacement: passo 1, immagine 2 di 2
    • Flip the camera so that the bottom is facing you.
    • Take a spare coin and unscrew the battery cover off.
  2. Minolta X-370 Battery Replacement: passo 2, immagine 1 di 1
    • Remove the batteries, making sure to note their proper alignment.
Conclusione
Altre 4 persone hanno completato questa guida.
Nick
Membro da: 04/19/11
525 Reputazione
4 Guide realizzate
Cal Poly, Team 8-7, Regan Spring 2011 Membro di Cal Poly, Team 8-7, Regan Spring 2011
CPSU-REGAN-S11S8G7
4 Membri
4 Guide realizzate
Un commento
Hi there, i'm a bit stuck, in my 35mm SLR i was taking a shot and the batteries died, leaving the mirror stuck in the up position, i've changed the batteries and the release for the shutter won't click, i can't advance the film lever and so it's a sitting duck at the moment. They're brand new batteries but because the mirror is up i can't even see if the metering works. because i'm half way through a roll of film i don't want to open the back and ruin it so i'm wondering if there's any way to get the shutter to release again or to get the mirror back down, i don't mind loosing a few blank exposures but again i really wouldn't want to ruin the film. Many thanks and i hope you can get back to me,
Cameron
Cameron Tyson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 31
Ultimi 30 Giorni: 180
Tutti i Tempi: 18,540
