Salta al contenuto principale
Minolta QTsi Maxxum Lens Replacement
Cosa ti serve
  1. Minolta QTsi Maxxum Lens Replacement, Lens: passo 1, immagine 1 di 2 Minolta QTsi Maxxum Lens Replacement, Lens: passo 1, immagine 2 di 2
    • The lens release button is located on the right front side of the camera.
    • Remove the lens from the camera by pushing the lens release button.
  2. Minolta QTsi Maxxum Lens Replacement: passo 2, immagine 1 di 1
    • The detached module has multiple screws that must be removed in order to reach the lens.
    • Once detached, remove the (4) black Phillips #00 5mm screws from the outer rim of the module.
    • Next, remove the (2) remaining black Phillips #00 5mm screws.
  3. Minolta QTsi Maxxum Lens Replacement: passo 3, immagine 1 di 2 Minolta QTsi Maxxum Lens Replacement: passo 3, immagine 2 di 2
    • Once all screws have been removed, take the back piece off of the lens and replace it.
    • This piece should come off easily without using any tools.
    • There is film underneath the last 2 screws that are removed so be careful when taking it out because it could rip.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 622
